Previous in Forum: How Can I Amplify My Hydraulic Pressure?   Next in Forum: Coating Glass Panels With Low Viscosity Fluid
14 comments
Good Answers: 56
Speed Regulators for Single Phase 120VAC Motors
01/24/2012 4:32 PM
I use several variable frequency phase inverters to operate my 3-Phase 220VAC machines on the available Single-Phase 220VAC.
I also have variable frequency oscillators to drive my 24VDC machines.
Now I have need for safely regulating the speed on a deWalt radial arm saw that has been converted to use as a lapidary machine.
I need to tame the high speed. It's equipped with a 2.5 horsepower, single phase 120VAC motor. I do not expect to load down the motor so, except for start up, the current draw will be modest.
Efforts to find a solid state regulatory device have come up short.
I can find many such devices for resistive circuits but none for inductive loads that operate on 60 cycles.
Can someone help me please, with a solution that does NOT require changing the motor?
Thanks!
Laughing Jaguar
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
Re: Speed Regulators for Single Phase 120VAC Motors
01/24/2012 5:18 PM
I would think it may be easier to just reduce the speed via reduction gear....
Good Answers: 56
01/24/2012 10:28 PM
Thanks for the suggestion but the speed must be variable slow to medium and gears do not support that.
It would be simpler to swap out the motor for a three-phase unit but that would prove too costly to a degree I am not prepared to experience.
I appreciate the thought.
LJ
01/24/2012 10:44 PM
What about something like this?
http://variablespeedmotor.net/
01/24/2012 11:15 PM
How about a variac simple and available.
Good Answers: 56
01/24/2012 11:41 PM
I have three Variacs, "Auto Transformers", but never considered them as they reduce voltage. My memory of this alternative is that while that does reduce motor speed, the amperage on inductive loads tends to skyrocket as the voltage drops. Eventually the motor burns up.
Nice try!
Thanks for attempt.
L.J.
Good Answers: 119
01/25/2012 2:33 AM
fyi
Three-phase VFD's reduce frequency AND voltage in proportion to maintain a proper V/Hz ratio and provide full rated motor torque over the entire speed range.
A Variac will only reduce voltage. Some motors can be effectively speed controlled on reduced voltage alone. All my power tools can be speed controlled when connected to my 20A Variac. However, full torque is not be available at any speed below rated RPM.
"Motor burn" may occur from running any motor at partial speed because the integral cooling fan may not be able to move enough cooling air at reduced RPM.
Good Answers: 114
01/24/2012 11:46 PM
01/25/2012 12:00 AM
There are single-phase VFDs.
Good Answers: 19
01/25/2012 2:39 AM
Although most VFD's are designed for 3-phase motors, at least one company does indeed manufacture VFD's for single-phase motors.
http://www.anaconsystems.com/text/opti_e2.html
By the way, the DeWalt Radial Arm Saw uses a capacitor-start induction motor, either 1/2 or 3/4 HP.
Wolfe Machinery Co. carries parts for DeWalt radial arm saws, and might still have a manual available.
Good luck.
01/26/2012 1:39 AM
For what the VFD costs you could buy a lapidary machine complete....and that's neglecting the max hp rating...I don't think it can be done economically...and reliably...
Good Answers: 119
01/25/2012 2:12 AM
Many tools in this HP range and lower use a universal AC/DC brushed motor. A router speed control or one of your variacs (if large enough) should work fine.
If it's really an induction motor, then the single phase VFD may be your only option.
Good Answers: 102
01/25/2012 6:18 AM
That was my thinking too.
Cooling will be a serious issue at slower speeds. May need a blower to disperse trapped smoke when it is released..
Belgium - Member - New Member
Good Answers: 21
01/25/2012 5:34 AM
Rewinding the motor as a 3 phase 4 or 6 pole motor and using a VFD to controle the 3 phase motor ...
Good Answers: 114
01/25/2012 10:37 AM
running for extended periods as you would for lapidary work, cooling will indeed be a problem
a more traditional rocksaw arrangement will likely be a better solution
another area of concern cutting fluid, consider using mineral oil, which is less toxic than motor oil
Register to Reply 14 comments
bubbapebi (1); Garthh (2); Laughing Jaguar (2); LOCKDUKE (1); mjb1962853 (2); rudy.leurs (1); SolarEagle (3); Tornado (1); Wal (1)
