Previous in Forum: Torque to Tighten an M8 Brass Nut   Next in Forum: Checking Vacuum Conditions in Vacuum Towers
Compressors and Boosters for Drilling
05/03/2007 4:11 AM
Drilling in Total Losses and Problems Anticipating:
Drilling 17 ½" vertical holes to the depth of 1000 meters with air and foam.
What capacity of compressor and booster is required to lift the cuttings in the annular to surface?
Basic Compressor: 350 psi, 1150 cfm.
Compressor Booster: What psi and cfm is required?
How many basic compressors are required?
Please advice whether one screw compressor is enough to one compressor booster?
Following are the details:
1. Drilling with 5 ½" DP, 17 ½" Stabilizer, 8" DC + 6 ½"DC + 5" HWDP.
2. Drilling Depth - 1000 m. Vertical Hole.
3. Drilling in Sedimentary Zone.
4. General History of Total Losses:
a. Frequent; partial to total losses: 0 to 300m
b. Frequent; total losses: 300 to 450m
c. Infrequent; dynamic: 450 to 625m
d. Very infrequent; partial: 625 to 675m
e. Very infrequent; dynamic 675 to 775m
f. Very infrequent; partial 775 to 975m
5. General Litho logy:
a. 0 to 150m: Calcareous dolomites, shale and argillaceous L.St.
b. 150 to 230m: Dolomites; gypsum/anhydrite
c. 230 to 350m: Fossiliferous Lst./argillaceous L.St.
d. 350 to 450m: L.St. – Fossiliferous.
e. 450 to 475m: Shale – Grey in color and plant remains.
f. 460 to 630m: Interbedded sequence of L.St. & Shales.
g. 630 to 675m: Shales- varicolored – olive, brown, green.
h. 675 to 775m: Carbonate sequence of L.St. & Dolomites.
i. 775 to 875m: sequence of sub-feldspathic to sub-arkosic S.St., Siltstones, and mudstones/shales.
j. 875 to 950m: top 5-10m red brown claystone. Sequence of sub-feldspathic to sub-arkosic S.St., Siltstones, and mudstones/shales. Shales are red purple and green in color.
k. 950 to 1000m: marine gray shale. Marine sandstones.
6. General Hydrogeology:
Static Water Level: 120 to 140m below ground level.
7. If any body can guide me mud pump capacity?
Re: Compressors and Boosters for Drilling
05/04/2007 1:04 PM
If you have not purchased a drill yet:
you should buy a Foremost DR24 drill rig to be able to set large casing to depth and drill hole at the same time and then you can drill using reverse circulation to the desired bottom depth.
and by using the casing drill rotator in combination with the drill head for torque to drill the hole you will go to depth with ease and avoid the need for a compressor using reverse circulation mud drilling.
forget using a compressor with that diameter and depth as it iwll be a real energy hog and use reverse circulation mud drilling with a shale shaker.
if you insist on air drilling look at 1150/350 compressors in triplicate
You might be interested in: Drilling Rigs, Compressor Repair Services
