Previous in Forum: Electric Bicycle   Next in Forum: Current Limiting to 80 Amp
Filter Desin for an Inverter Circuit
01/26/2012 11:46 PM
I am design a filter without any load. It gives output perfectly a sin wave. But waveform becomes distorted when i applied load. So please tell me the design procedure of filter which will be independent of load
Pathfinder Tags: Filter design
Good Answers: 119
Re: Filter Desin for an Inverter Circuit
01/29/2012 9:32 AM
Active filters, those designed around op-amps for example, are mostly load independent. As long as the op-amp can drive the load, the filter characteristics should be close to ideal.
Passive filters, those using only resistors/capacitors/inductors, MUST be designed for a specific load impedance. As the load impedance changes, so will the filter characteristics.
