Previous in Forum: Loading of a Transformer   Next in Forum: Standard Color Codes for Single Phase 220VAC
ABT Rectifier
01/28/2012 11:58 AM
Dear Engineers,
May be the question I am asking is looks silly,but i am confused about it so please give clarification.
In 3 phase rectifier we are using 6 thyristor and if we give 415v ac it will come around 560v dc at output when we measure with our voltmeter.
Now if one of this 6 thyristor was not getting firing signal or it was bad (not conducting) then output voltage when we measure with voltmeter will show 560 v dc only? Is this right, or is there any changes in o/p voltage? As our voltmeter measures peak value. How we can find out there is problem in 1 thyristor?
Thank you
Re: ABT Rectifier
01/29/2012 12:18 AM
Simple way will be thus:
Filter the harmonics out of a "DC Volt-Out " measuring circuit--branching from Rectified output-- which is loaded with a constant heavy resistive load RL .
You are suspecting that 1 of the 6 -not working:
Take the reading=V11.RL is the load.
Now disconnect any one thyristor. Load as before .Take the reading=V12.RL is the load
Likewise 4 more times --take readings V13>>V16-all tested. RL is the load each time .
Now see which being disconnected made no difference. That is the FAULTY one .
Re: ABT Rectifier
01/29/2012 8:29 AM
In that case only 2 Φs are conducting in full wave. It will give as much output but ripple may increase on full load.
If you have a CRO try to measure ripple on both conditions [disconnect filter]
See Rectifier
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
Re: ABT Rectifier
01/30/2012 6:55 PM
You won't see much voltage output difference at all when one diode opens, you will see whatever the rectifier is powering get VERY hot, then you need a scope to find which is bad/not-firing. Now if you have a blown fuse DON'T replace it until you check if one of the diodes/SCR's are still shorted, then you won't have to use a scope to find the open/not-firing one.
in the real world the voltage drop isn't useful for troubleshooting 6 diode circuits
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
Register to Reply 3 comments
Haajee (1); kwcharlie (1); MUKULMAHANT (1)
