Previous in Forum: Could This Machine Actually Work?   Next in Forum: Spring Calculation
9 comments
Steel Equivalent
01/28/2012 11:45 PM
Can anyone help to find the equivalent to the following:
SAE 4130 tube.
1018/1020 grade rod.
44w plate
en30B round bar
8620 grade hex bar.
thanks in advance.
"Let my body and its pain take care of each other, thou my mind will always be in a bliss"
Re: Steel Equivalent
01/29/2012 2:22 AM
Equivalent in what way? price strength weldability corrosion rust resistance ridgitity weight chemical composition density stress resistence??
01/29/2012 6:01 AM
Equivalent in other standards.....like BS, EN etc.
01/29/2012 4:53 AM
SAE 4130 tubes equivalent:
25CRMO4-25CD4-1.7214 Steel Tubes
Chemical Composition:
C
Si
Mn
S
P
Cr
Ni
Mo
0,22 0,29
0,15 0,25
0,50 0,80
≤ 0,015 ≤ 0,020
0,90 1,20
≤ 0,30
0,15 0,25
Quantity
Value
Unit
Young's modulus 205000 - 205000 MPa
Tensile strength 660 - 810 MPa
Elongation 12/16/11 %
Yield strength 390 - 510 MPa
Thermal expansion 15 - 15 e-6/K
Thermal conductivity 47 - 47 W/m.K
Specific heat 420 - 460 J/kg.K
Melting temperature 1500 - 1500 °C
Density 7800 - 7800 kg/m3
Resistivity 0.15 - 0.2 Ohm.mm2/m
01/29/2012 9:21 AM
Do you have search engines available? If so it's a simple matter to do some basic searches and determine the answer for yourself. That's really elementary, you know.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
01/29/2012 4:51 PM
Check with your supplier, they should either know the information of be able to give you the documentation showing the equivelants.
Regards,
Sapper.
It's all about the Boom! - MythBusters
Safety - Hazmat - R&D Engineer/Inventor
01/30/2012 8:35 AM
This link will answer all of your questions. I may even download it myself
WinSteel (you need to purchase software)
Equivalent Grade (free but limited)
masterblaster
01/30/2012 11:49 AM
SAE 4130 tube.
Good morning,
Attached is my favorite stop for material inquiries/conversions - really indespensible when researching virtually any material. Super extensive database.
Good luck!
http://www.matweb.com/
Good Answers: 266
01/30/2012 1:55 PM
02/01/2012 12:00 PM
Thanks Ozzb...I was looking for a pdf
Register to Reply 9 comments
Damon Taylor (1); lyn (1); masterblaster (1); Mukesh0861 (1); ozzb (1); Sapper (1); Sengottuvelavan (1); SolarEagle (1); sridharyaamunan (1)
