Previous in Forum: Sampling Rate Of A Control Loop, In A Process Plant   Next in Forum: Solenoid Valve Operation
9 comments
Modicon TSX TIO
01/30/2012 2:22 AM
Hi guys, currently i'm looking for 170 QPR 330 00 8 input & 4 output Telemecanique/Schneider PLC for my client, all ready contact local Schneider distributor but they told me Schneider already stop their production.
Done searching the net but still I cannot find the supplier. Can any body from this forum help me please?
Re: Modicon TSX TIO
01/30/2012 2:41 AM
For this type and size of PLC, you might find some very similar ones from Omron or Mitsubishi, to name two. You might also look for "programmable relays", but I'm not sure they will have enough I/O for your app. Some alternative architectures include Galil and Opto-22. You can probably Google all of these and see what comes up.
Re: Modicon TSX TIO
01/30/2012 2:59 AM
Yes I already advised my client to change their mini PLC with a new model but still insist to used old QPR model and its very difficult to find such PLC even used.
Re: Modicon TSX TIO
01/30/2012 3:31 AM
Well, I don't know what to do when the client (or boss) is totally dumb. This happens much too often.
Re: Modicon TSX TIO
01/30/2012 11:25 AM
Re: Modicon TSX TIO
01/31/2012 9:08 AM
You might have to add another module so that you have a 24vdc 16 pt input and then a 24vdc 8 or 16pt output.
Is this used with either the Compact for the Quantum as a remote I/O point? I never used these remote's. I always used the Momentum with the right adapter, it will do the same thing.
Jim B
rrnut-2
Good Answers: 21
Re: Modicon TSX TIO
01/31/2012 6:24 PM
I am sure you have done the internet search for this unit and came a-way with 0 items. Your choice on these units is to upgrade or just upgrade. From the serial number it looks like this is an 85 model and long out dated.
You might contact the supplier and ask if they have any records where they might have sold these units to. Maybe you can get someone to look on spare parts shelves and see if there is one laying around.
Good Luck
Re: Modicon TSX TIO
10/23/2012 11:05 PM
Hi!
how you solve this problem?
because, i'm looking this Modicon TSX TIO also.
Thanks in advance.
Re: Modicon TSX TIO
10/24/2012 12:16 AM
Replacement by new model.... solved
Re: Modicon TSX TIO
10/24/2012 12:21 AM
What model you used to replace?
Can let me know?
Register to Reply 9 comments
edwin87 (2); fixitorelse (1); rrnut-2 (1); SolarEagle (1); Tornado (2); visaseller (2)
