Previous in Forum: Who Installs Rooftop Solar Systems in France and Spain?   Next in Forum: Control Board Inside the PIM for GM's Old EV1 Car
3-Phase to 1-Phase Amperage Draw
05/03/2007 10:37 AM
I would like to know what the amperage draw would be for a 2000 watt heater
at 208v 1 phase and at 208v 3 phase.
Good Answers: 27
Re: 3 phase to 1 phase
05/03/2007 10:48 AM
Single Phase Watts = Volts x Amperes x Power Factor
Three Phase Watts = Volts x Amperes x Power Factor x 1.732
Re: 3-Phase to 1-Phase Amperage Draw
05/03/2007 2:34 PM
Single phase at 208v = 9.6A
Three phase at 208v = 5.54A
05/03/2007 3:08 PM
Thank you for your responses.
05/04/2007 2:09 AM
single phase= 2000/208
three phase= 2000/208/3
assume heaters are resistive not inductive nature
05/04/2007 5:43 AM
To adapt this heater between single phase and three phase, it would require 3 separate elements which are assumed to be resistive so there is no Cos component involved in the calculation.
In single phase mode the three separate elements would be combined in parallel with a total load of 2000W/208V = 9.6A.
Because you are quoting a 3 phase Line voltage of 208V which is the same as the phase voltage, the resistance/voltage relationship per phase is equivalent to one element at 65ohms and as there is no benefit of a higher voltage on the three phase supply then the phase current is the same 208/65 = 3.2A per phase.
When the higher voltage is not applicable the 1.732 component does not apply.
Did you mean to state 208V - 3 phase?
Good Answers: 18
05/04/2007 8:22 AM
Uh . . . At what voltage is the heater rated for 2000 W? If it's a 240 V heater rated at 2000 W, then it won't put out 2000 W at 208 V. 208 V is 208 V whether it's 1 phase or 3 phase.
05/05/2007 5:43 AM
Bill is correct.
The element resistance is designed according to the rated design voltage of the equipment and the correct answer to your question requires the original rated voltage.
Your other replies are also correct - on the basis of your information the single phase current is 9.6A
If the element is Star connected to a 3 phase -4 wire supply, then the phase current is 3.2A
If the elements are Star connected to a 3 phase 3 wire supply the phase current will be 1.85A
If the elements are Delta connected to a 3 phase 3 wire supply the current will be 5.5A.
Anonymous Poster (5); Bill (1); Bluestone (1)
