Previous in Forum: 990 Volt Power Meter   Next in Forum: Neutral to Ground Voltage
8 comments
AVR- Installation
01/30/2012 12:04 PM
Hi, I'd like to know, what's the preferred location for installation of AVR? Is it at the line side or the load side?
What do you think is suitably best, say I have a step-down transformer 460V to 380V, where shall I put the AVR preferrably considering cost and economical life issues.
Re: AVR- Installation
01/30/2012 12:44 PM
Anything that can improve the quality of the power supply should be installed first...
01/30/2012 8:59 PM
You mean shall I put first AVR than transformer? What if Line side is 460V and load side is 220V. Will price don't matter that much for 460V and 220V AVR?
Good Answers: 58
01/30/2012 1:22 PM
Is the AVR controlling the output of a generator?
01/30/2012 7:11 PM
Nope, it's provided to isolated expensive equipment.
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
01/30/2012 7:18 PM
are you the OP? if so go AWAY, we all know what a AVR is, TIME IS $
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
01/30/2012 9:00 PM
If you knew why not answer? Dont claim you knew when not.
01/31/2012 10:12 AM
It was just the idea of you saying the AVR was a or isolation device, and didn't control the output of anything, never mind, since I was so short I'll answer your question:
If your speed regulator works off magnetic pickup or some other tach like device you can mount the AVR at the generator, supply side the best IMO.
If your speed regulator works off the Hz of the generator you should mount the AVR on the load side so the generator gets excited as it comes up to idle and the speed regulator has something to look at.
02/19/2012 6:21 AM
bro AVR regulates the output voltage. its a electronic device. if we talk about ship's gen. AVR are placed in engine control room where A.C'S are provided. it will keep AVR safe from high temprature. thus increasing the life of it. no doubt we have to provide few no.s of more electric wires from engine control room to the generators. but wiring is one time investment which will make the AVR life increased.
if u r putting avr on line side note that here voltage is high(460v) and thus current will be less. but on load side voltage is low(380v) but current will be high.
and on both the sides load will be the same. so i think u should 1st see what is the AVR capicity which is cheaply available to u.
Anonymous Poster (3); KJK/USA (1); kwcharlie (2); pardeepmanhas86 (1); SolarEagle (1)
