Previous in Forum: AVR- Installation   Next in Forum: Circuit Breaker Rating
Neutral to Ground Voltage
01/30/2012 2:58 PM
What is the maximum limit of neutral to ground voltage?
thanks in advance
Re: neutral to ground voltage
01/30/2012 3:02 PM
Will this voltage be transmitted through conductors? What is the size?
01/30/2012 3:31 PM
The maximum neutral to ground voltage limit is set by your local wiring codes.
01/30/2012 11:58 PM
Please suggest me some links leading to some standard of neutral to grounding voltage i.e IEEE, IEC, NEC.
Re: Neutral to Ground Voltage
01/31/2012 4:04 AM
As has been discussed in this forum many times before, a voltage on the neutral with respect to earth is simply the expression of the neutral current and the earth loop impedance:
http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=neutral%20voltage&order=asc
02/02/2012 1:05 AM
no one mentioned any snadard of maximum neutral to ground voltage.
please tell if you know.?
02/02/2012 9:48 AM
Nobody mentioned which location are these wires. It is the location that identifies which are the local codes. The local codes are the relevant standards.
Endless loop paradox, endless loop paradox, endless loop paradox, endless loop paradox, endless loop paradox, endless loop paradox, endless loop paradox, endless loop paradox, endless loop paradox....
<reboot> "bleep" a happy little penguin
How may I help you?
02/03/2012 12:26 AM
Register to Reply 7 comments
iftikhar129 (3); lyn (1); PWSlack (1); redfred (2)
