Previous in Forum: What Adhesive is Used on the Front Covers of Magazines?   Next in Forum: Dibenzosuberenone - TCO
Eliminate Micro-Organism Growth in a Water Tank
05/03/2007 10:53 AM
Dear all,
I'm looking for a solusion about the next issue:
I have a water tank that flow water with diaphragm pump through some 'Z' and back to the water tank , my problem is that if i won't use the water tank, it will be full with micro organism and verdant, i'll be glad to get some idea how to prevent that problem and how to handle if it's already occure.
thankes in advance.
Re: Eliminate Micro-Organism Growth in a Water Tank
05/03/2007 3:08 PM
What is the water used for? The nature of the treatment depends on its end use.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
05/03/2007 11:46 PM
The most common method is to inject chlorine.
John
05/04/2007 1:38 AM
The elimination of undesirable micro organisms in a water tank if desired,it is necessary to make empty that tank first.then thorough cleaning and complete scraping should be carried out so that the colonies developed by m.o. must be waved off.The whole tank then must be filled with 1-2% solution of Hcl for atleast 4-6 hrs.The tanks walls and bottom should be coated with lime solution Ca(OH )2,must be dried out completely before taking in line.
05/04/2007 9:14 AM
Actually a common problem with coolant tanks in machine shops.
The tanks will begin to smell after about a week
We use 1/2 box of baking soda in the tank each time it is refreshed.
Odor problems are gone. Tank life nearly doubled. Cheap and effective.
United States - Member - USA Engineering Fields - Control Engineering - Never enough money
05/04/2007 12:28 PM
Chlorine, baking soda (sodium Bicarbonate) and many other chemicals are good options for preventing and removing bio growth from water tanks and piping. What we really need to know in order to give the best advice is "what is the application?". Is the water used for drinking? Is it used for cooling a Nuclear reactor? Then what are the materials of construction, HCL and other chemicals don't always play well with certain materials.
In general non specific applications a 3ppm to 6ppm concentration of chlorine should meet your most of your needs at a very low cost.
Good Answers: 101
05/25/2007 5:44 AM
Use a 254 nm UV lamp. It will disinfect your tank.
Register to Reply 6 comments
Anonymous Poster (2); BrainWave (1); DVader1000 (1); muhammad jamal (1); Richard L (1)
