Previous in Forum: Prototype Building   Next in Forum: Buying Tungsten Products from China
Be Not Strange to Dewatering Screen Any More
01/31/2012 2:58 AM
Application Of Dewatering Screen:
Dewatering Screen is widely used in coal preparation, mineral processing, building materials, construction,electricity and chemical industry products classification purpose,dehydration, tailings recovery. Dewatering Vibrating Screen has the vibration motor with the same performance parameters as excitation source, when two sets of vibration motor in the same angular velocity do reverse operation, the inertial force produced by an eccentric block in a particular aspect torepeated stack or offset, so as to produce a great shock, driving the screen box along the straight line track to do periodic reciprocating motion, make the materials on screen mesh from input to output to do gradually vibrate, during the vibrating process the part less than the screen hole (water) through the sieve hole falls, the rest from the output falls, so as to achieve the purpose of classification, dehydration.
Dewatering Screen Features:
1.The vibration motor is vibration source, adjustable amplitudes, simple, reliable and convenient maintenance. 2.Equipped with high wear-resisting and anti blocking polyurethane screen, based on years of product design professional knowledge, modular degree is high, it is easy to change. You can free downtime and loss of lost productivity, which can reduce the operation cost.
3.Adopting 45 degrees standard anticline feeding area design, and using the centrifugal force to have a auxiliary dehydration, can improve the dehydration effects and it is more convenient to transport dehydrated materials. 4.It can adjust the screen angle quickly, so that adjust production processes subtly, and realize the maximization of the production and efficiency.
5.Side plate and reinforcing plate, the connection between steel beam, all adopt the special high strength ring groove rivets to rivet, resistance shear strength is high, anti vibration, never moves rivet, to avoid the side plate cracking accidents caused by the welding defects. 6.Low alloy structure steel made by (Q345C), can make the equipment in -40 °C cold region-still can ensure the overall rigidity.
Dewatering Screen Structure:
GT series dewatering screen is generally consist of exciter, screen box, screen mesh, brackets, damping device and other components.
Re: Be not strange to dewatering screen any more
01/31/2012 7:54 AM
I was planning to build a coal-fired power plant in my back yard, but the one thing I was hesitating about was the dewatering screen; I'd never used one before and I just wasn't sure about maintaining the vibrating motor or adjusting the angle of the screen or whether it would really improve the dehydrating effect.
Your post has allayed my fears and I feel confident now, and I won't be strange to dewatering screens anymore. I just hope the smoke and the noise don't bother the neighbors too much.
