Previous in Forum: Marine Wind Generator Setup?   Next in Forum: Electrical Circuit Contact Points & 'Gounding' Switch
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Solar Tracking System
02/01/2012 11:10 PM
I want the speification of a stepper motor that are capable of rotating 2 kg solar panel. And also pls mention the type of stepper motor to be used. reply soon pls!!!!
All is well !!! All is well !!
India - Member - New Member Popular Science - Cosmology - New Member
Re: solar tracking system
02/02/2012 12:03 AM
02/02/2012 12:16 AM
thank u so much..... and one more que! is it necessary to keep step angle 1.8 deg? for my project i calculated step angle 10.9 deg / hr..... varying the solar panel according to the sun's position. initial position of panel ll be 45 deg facin the sun at morning.then moving the panel by motor in steps at 10.9 deg/hr. am using this for 11 hours a day. so totally 120 degree ,the panel should move! is it ri8.... reply soon pls. its urgent!
02/02/2012 1:27 AM
How did you come to a 10.9 degrees per hour?
Also; it would seem that the smaller the increment steps the better average angle on the collector.
If you have it mounted on good bearings it should not require a lot of torque to turn a 2.5 KG collector.
This very interesting topic was discussed in another thread.
I will try to find it.
02/02/2012 1:49 AM
reply me soon sir!!!!! pls.................
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
Location: Chennapattanam (Coromandel Coast of the Bay of Bengal).
02/02/2012 2:23 AM
02/02/2012 4:31 AM
Urgent replies cost extra. Can you afford it?
When is your project due?
Re: Solar Tracking System
02/03/2012 10:54 PM
http://cr4.globalspec.com/thread/66442#newcomments
The thread above discussed the advantages and disadvantaged of tracking collectors.
It included a lot of good links related to the topic.
Register to Reply 7 comments
BAI (1); bharath boss (2); Gavilan (2); lyn (1); mandi (1)
