Hi!
We are using 33kva supply for our factory. In the past two months we had PT failures twice and CT failure once in the metering cubicle of the electricity board. Our operations are on 50% average of contracted load. We have meggered the earthing and found values of 1 to 1.5 ohms. We have tested insulation of the XLPE cable between the pole & metering cubicle and between Metering cubicle & Isolator and found okay. The PTs and CTs have been working okay for the past three years. We are having foggy atmosphere here recently and the PTs failed even after keeping the room ventilated and heated. The failures have stretched everyone's imagination here and we are not able to pinpoint the reason for failures.
We require to know all probable reasons for failure of PTs.
We require to know all probable causes for failure of CTs.
Thanks.
Ragotham
