Previous in Forum: Controller   Next in Forum: Supply Air Header Pressure Falls From 100 to 50 PSI - Will Regulator Output Fail?
What is a Sleeve Repair Kit for Control Valve?
02/08/2012 1:37 AM
What is a sleeve repair kit for control valve
Re: What is a Sleeve Repair Kit for Control Valve?
02/08/2012 2:23 AM
Many control valves have shafts that slide or rotate within a sleeve (or bushing). The sleeve can wear out. A kit may include a new sleeve plus various seals that should also be renewed. It all depends on the specific valve construction.
