Previous in Forum: Pipe Network-Arriving System Curve   Next in Forum: Polar 115
Bending of Galvanised Pipe
02/09/2012 4:11 AM
Hello,
I have a 6inch pipe,bended to 90degree almost,to be galvanised by dipping.
We normally galvanisng on stright pipes only.
if anybody have experience in doing galvanisng on bend pipe please share the procedure,equipments and holders of dipping the same.
Thx and Regards,
RR
Re: bending of galvanised pipe
02/09/2012 4:20 AM
Just push it into the zinc bath, with the ends upward so that air is not entrapped. Then, when lifting it out, turn the ends downward so that the zinc drains away. If you are not doing so already, wear respiratory gear to avoid breathing the fumes.
Retitle the thread as "Galvanising of Bent Pipe"; this being the actual order of events.
Re: Bending of Galvanised Pipe
02/09/2012 7:25 PM
If you are outsourcing your galvanizing which most do, make sure you are aware of the tank dimension as you could have limitations on the physical size of pieces being dipped.
02/10/2012 4:38 AM
if u are aware, can u share the process of doing galvanising of bend pipe.
My intention is to know how to hold it properly for dippng in the bath.
ralish
Register to Reply 3 comments
pipeit (1); ralish (1); Tornado (1)
