Previous in Forum: How to Change Varying Voltage From 400-100 Vdc to a Constant 12 or 48 Vdc   Next in Forum: Which Connection to Motor 5HP or Above, Star or Delta in DOL
Vector Group of a Transformer?
02/10/2012 9:23 AM
I was studying single line diagram. And saw a Vector group written with the transformer it was Dy11. I couldnt understand it I go through internet but my concepts about vector was not clear kindly tell me what is meant by
Dy11
Dy1
Yd11
Yd1.
Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction. Albert Einstein
Pathfinder Tags: Transformers vector group
Re: Vector Group of a Transformer?
02/10/2012 5:17 PM
Check here
02/11/2012 12:10 AM
How about here http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=Vector%20group&srchobjs=t%2Cc&fs=12&order=asc
02/13/2012 12:48 AM
Dy11 = Delta connection primary winding: Star connection secondary winding.
The difference between a Dy11 (delta winding lags the wye winding by 30 degrees) and a Dy1 (delta winding leads the wye winding by 30 degrees) is a phase shift. One is not better than another in a general sence. Depending on the configuration of the plant and surrounding power lines and transformers, one may be more beneficial than the other by allowing the plant to sync to the grid through multiple sources without first disconnecting.
There other two might be the opposite of the first two. #not sure#
Good Answers: 170
02/16/2012 10:02 AM
If you will send me your mail ID throi this forum's mailbox, I will send you a paper authored by me on the subject.
02/18/2012 8:25 AM
My feind waiting for your reply
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Anonymous Poster (1); electricalexpert65 (1); wareagle (1); waseemijaz_89 (1); WisdomJD (1)
