Previous in Forum: Abot WPS/PQR/WPQ and Selection of Welding Electrodes or Filler Wire   Next in Forum: Nace SP0198
Low Pressure Steam Required for Liquid Chlorine Vaporisation
02/11/2012 12:10 AM
Need some guidance to calculate low pressure steam required (2.4 kg/cm2 @ sat.temp) for vaporizing the liquid chlorine from the 1 ton tonners as around 400 kg/hr of chlorine gas at 5 kg/cm2 & 50 deg.C is to be supplied to process plant which is located around 500 mts away from the gassifier.Also the specific volume of the chlorine gas for calculating the pressure drop and line size may also be indicated.
Re: Low pressure steam required for liquid chlorine vaporisation
02/11/2012 1:45 AM
Compare the latent heat of evaporation of steam versus that of chlorine. This will tell you how much steam flow you need; and then add some for various losses.
02/11/2012 1:53 AM
02/11/2012 3:38 AM
Thanks for the prompt reply and appreciate if it can be guided to arrive at the figure for specified conditions for sizing the piping.
02/11/2012 9:33 PM
Re: Low Pressure Steam Required for Liquid Chlorine Vaporisation
02/13/2012 5:47 AM
calculate the heat required for vapourising chlorine from 1 ton tonners at given pr & temperature. thsi heat will be equivalent to evaporation of steam. use MCpdT = constant ,for solving the problem
Anonymous Poster (1); SolarEagle (2); Tornado (1); Umeshgupta (1)
