Previous in Forum: Reactive Power Compensation   Next in Forum: Auto Transformer
Clamp Meter
02/13/2012 4:08 AM
How a clamp meter or tong tester works for all type of CT's?
Re: CLAMP METER
02/13/2012 4:15 AM
Google "clamp meter", preferably having turned off CAPS LOCK first.
Re: Clamp Meter
02/14/2012 5:30 AM
I really dont understand your question. Are you asking a question as "how is the clamp meter of the tong tester works as compare with the CT's"?
Re: Clamp Meter
02/22/2012 1:15 AM
Sorry for the mistake i have made.I need to know how the clamp meter works?
Re: Clamp Meter
02/22/2012 4:01 AM
Basically, the clamp meter or sometime we call the Tong meter works by the electromagnetic principle. As you know that the electric cable, either copper or aluminium, that curry electric current will produce electromagnetic flux along the cables.
By using the clamp meter, the clamping tong (Jaws) which is made of laminated steel plates will cut the electromagnetic flux and convert the EMF into voltage. By some resistor, transistor and other electronic devices, that build inside the clamp meter, it convert the voltage and energize the moving coil where it deflected the needle according to the strength of the voltage or in this case, is the current inside the copper cables.
Register to Reply 4 comments
PWSlack (1); sathish-47 (1); Simon Wan (2)
