Previous in Forum: Safety Valve Popup   Next in Forum: Design in Nature by Bejan et al.
Hydraulic Calculation: Water Storage Tank
02/13/2012 7:09 AM
Dear Friends,
I am preparing Technical report on water storage tanks. But I am also required to add hydraulic calculations. Since this is totally new concept for me, can anybody help me for this with references or sample?
Regards
ASP
Good Answers: 34
Re: Hydraulic Calculation : Water Storage Tank
02/13/2012 7:27 AM
API 650 (Chapter 3 desing) this Standard is for oil storage but can be applied to water storage. WP
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
02/13/2012 7:44 AM
You need more aptitude. Study from author R.S Agarwal
02/13/2012 8:13 AM
1 foot of water head = .43PSI.
Good Answers: 179
02/13/2012 8:31 AM
Please obtain a copy of American Water Works Association (AWWA) Standard ANSI/AWWA D-100, as well as API Standard 650.
Also, obtain the abstract: "Seismic Analysis and Design of Steel Liquid Storage Tanks", by
Lisa Yunxia Wang, California State Polytechnic University at Pomona.
Good Answers: 125
Re: Hydraulic Calculation: Water Storage Tank
02/13/2012 12:28 PM
Most water storage tanks fit in one of two categories.
1. Pumped: You must determine required capacity of tank, and flow rate/pressure for pump.
2. Non-pumped: You must determine required capacity of tank, and tank elevation. Start at most hydraulically remote location and use Hazen and Williams formula to determine line losses back to tank outlet. Add required pressure at remote location to line losses (minimize losses with stepped/larger pipe). Elevate tank (see post 4) to required height.
This is a very simplistic description, but is what the basics smell like.
CaptMoosie (1); hithuanand (1); lyn (1); Whitephone (1); WJMFIRE (1)
