Previous in Forum: Is PLC Only Required in All Industry?   Next in Forum: Carrier Shift
Fiber Optic Cable
02/13/2012 8:07 AM
Hi all, currently have ongoing project in Pakistan, we are running fiber optic cable in The electrical cable ladder, the electrical cable ladder have existing 22kv power cable please advise any interferance if the fiber optic cable lay. In the said ladder. Regard Mohd
Re: Fiber optic cable
02/13/2012 8:11 AM
It is very unusual for there to be any interference whatsoever between electrical circuits and fibre-optic cables.
02/13/2012 8:42 AM
The fiber optic cable must be kept full at all times. If the level drops below 75% you might get some interference at around 1.1 times the frequency at 22kv.
You will need demonic isolators if this is the case.
03/06/2012 10:08 PM
Forgive my ignorance, but a Cathode Ray Tube (television) springs to mind. Could not a sufficient magnetic field distort the path of photons, such as those within fibre optic cables. I assume it doesn't seen as it's 99.99% internally refractive??
The fibre optic cable must be kept full.......hehe good one
An educated man is not necessarily knowledgable, but has the intellect to call upon his resources.
03/07/2012 3:07 AM
Whoa! I have to correct the haneous confusion of sub atomic theory I just blurted out. Obviously fibre optics is not concerning electrons such as in a CRT. I really shouldn't type things that "spring to mind".
lyn (1); PWSlack (1); wopx8z (2)
