Previous in Forum: If Neutral Broken in Single Phase Consumers Distribution   Next in Forum: Reason of Tripping of All M.V & L.V Breakers Same Time.
12 comments
How To Find Out Direction Of Current H.T. Line
02/15/2012 9:36 AM
how to find out the direction of current in H .T. line. When there no any data plate on the poles or at the tower..?
India - Member - New Member
Good Answers: 164
Re: How To Find Out Direction Of Current H.T. Line
02/15/2012 9:55 AM
Not sure what you mean....in India, we use AC @ 50Hz, so it alternates direction 50 times in one sec.
On second thoughts, this is not really what you wanted is it? Please rephrase your question.
02/15/2012 10:54 AM
The safest way is to find out where the generation plant is. To mess with high tension lines which could carry voltages beyond 50,000 volts will kill, anyone who does not have the correct equipment and the knowledge to use them.
I thought I was trained but got zapped a few times. Thanks to God I am still alive.
That being said, measuring the AC voltage between different polls will give the direction. Assuming there is enough of a load to pull one side down.
Life long learning in an endless universe of possibilities! Just go for it!
Good Answers: 58
02/15/2012 11:13 AM
Attach an 8 foot fluorescent tube to a non-conductive pole of appropriate length.
Hold the pole over your head in close proximity to the HT line using one hand.
Note which end of the tube lights first. This will be the direction that the current is coming from.
Of course you must be holding a henway in the other hand for this to work accurately.
Now seriously, to answer your question, review the "one-line" drawing/schematic for the area of grid you are working to find the power source(s).
Given your question, do not climb any power poles, do not climb any transmission towers.
Stay away from HT lines or for that matter, any electric lines altogether.
Come in contact with an energized HT line and you most likely will NOT get a second chance to do it again.
02/15/2012 11:18 AM
What's a henway?
02/15/2012 11:24 AM
About a pound!
02/15/2012 11:27 AM
An oldie but a goodie. Well played!
Good Answers: 58
02/15/2012 11:55 AM
Ah yes, thank you both for filling in
Good Answers: 181
02/15/2012 1:07 PM
Good Answers: 58
02/15/2012 1:22 PM
Well, there you have it.....scientific proof
Good Answers: 804
02/15/2012 1:39 PM
Step 1; grab hold of a HT line with your RIGHT hand (see "Right Hand Rule")
Step 2; with no shoes, touch your LEFT foot to a grounded structure, such as the tower frame itself.
Step 3; Have a friend on the ground, a safe distance away, observe the direction in which your charred corpse twists as it burns. If it twists to your left, the current was flowing to the right and vice versa.
Good Answers: 58
02/15/2012 2:36 PM
02/15/2012 7:31 PM
I think you mean 'phase sequence' (checking which phase is which on a three phase system where the phases are not clearly marked).
Try an internet search for 'phase sequence indicator'
Register to Reply 12 comments
Doorman (2); jack of all trades (1); JRaef (1); KJK/USA (4); kvsridhar (1); MSEELady (2); TonyS (1)
