Previous in Forum: Cashpower Gemini   Next in Forum: Turbo Mechanics
8 comments
Need Formula, Miles per Hour/Gear Reduce Ratio
02/15/2012 2:11 PM
I have a few conveyor calculation formulas but I need to determine the gearbox ratio to use on a simple project and I am at a loss. I need to drive a shuttle car at 10 m.p.h., I have a 1750rpm motor and a 12" dia. wheel driven directly off of a gear reducer. Anybody have a formula for me to use?
Re: Need formula, miles per hour/gear reducer ratio
02/15/2012 2:42 PM
Well first I would convert the mph to fpm, 5280ft * 10mph / 60min....Now you know the rpm is 1750 so you must determine the circumference of the 12" gear or pi * diameter, this will give you fpm of 12" gear at 1750 rpm...Now with simple arithmetic you can determine the difference....
02/15/2012 4:50 PM
Thanks alot, I calculated a 6:1 gear reducer should get me to there.
Good Answers: 29
Re: Need Formula, Miles per Hour/Gear Reduce Ratio
02/15/2012 2:55 PM
Does 75 : 1 Gear ratio compute?
Think you might need more gearing.
Si vis pacem, para bellum
Good Answers: 125
02/15/2012 5:23 PM
Must first convert inches to feet.
Good Answers: 29
02/16/2012 4:44 AM
Oh yea, 37.7 ft per rev. IS quite a lot. Yep ratio is 6.25
Good Answers: 114
02/15/2012 4:47 PM
Well, I know that 60mph =88ft.second.
10mph = (88 feet/second/6)x60seconds = 880 feet/minute
880/π = 280.076 revolutions/minute.
1750/280.076 = 6.25 reduction.
I think.
Good Answers: 102
02/15/2012 11:35 PM
Surely, when you were qualifying for credentials that qualified you to be employed in a position requiring you to perform this calculation, you were examined and found to be competent at simple geometric modeling of physical problems......
You managed to work it out after a prompt, but....
Isn't there anyone working with you that can peer review your calculations?
CR4, peer reviewer of last resort.
02/16/2012 10:19 AM
Obviously if we all had the superior intelligence of Wal this forum would be redundant. I thank the rest of you who took the time to assist a mouth breathing neanderthal with grade school arithmetic sans snarky comments.
Register to Reply 8 comments
Biscayne (2); passingtongreen (1); PMoon (2); SolarEagle (1); Wal (1); WJMFIRE (1)
