Previous in Forum: Need Formula, Miles per Hour/Gear Reduce Ratio   Next in Forum: Book On Trusses
Turbo Mechanics
02/15/2012 2:49 PM
What is the balancing drum of turbine rotor and whats its function ?
Re: turbo mechanics
02/15/2012 3:03 PM
To balance out axial forces...
"... each stage of the turbine will produce an axial force in the direction of flow of steam proportional to the steam flow passing through that stage. The resultant axial force from all stages is balanced out approximately by a balance wheel located at the high pressure side of the rotor, whose job is to create a similar force to that created by the steam on the blading but in the opposite direction. The axial bearing will then have to cater only for the resultant force ..."
Good Answers: 32
Re: Turbo Mechanics
02/16/2012 11:21 AM
You may want to look at this previous thread
http://cr4.globalspec.com/thread/67110/Axial-Shift-Related-Problem-in-250MW-Steam-Turbine
There may even be some other earlier threads to review.
Spinco
Register to Reply 2 comments
