Previous in Forum: Better On-Off Valves   Next in Forum: Calculating Zinc Viscosity
17 comments
Popular Science - Weaponology - New Member Hobbies - Musician - New Member
Modulating a Laser Beam
05/04/2007 10:43 AM
Hi All.
I was wondering if anyone knows of a way (other thean mechanical) of attenuating a laser beam using something like a transparent chemical (liquid or gas) that changes properties when an electrical current is applied -say, thru electrodes- to translucent or opaque partially or blocking any light going through it? Kind of like electrochromic "smart" glass but needs to be much faster: 1 Khz or so..
Thanks in advance
Steve
PS- I can't use an AOM in this app. Also:the laser is a sealed potted unit with no access to the driver board/ internal electronics. The laser specs are:DPSS 532nM 245mW random polarity 3mm bd. Thanks Again for any info; experimental chemical or other.
Re: Modulation of a laser beam
05/04/2007 10:56 AM
Why not an LCD screen you can blink it on and off.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
05/04/2007 11:03 AM
Hmm- I think I might have seen something like that- a clock or something
Thanks! I'll try googling "LCD screen" The only problem might be heat dissipation in the screen. Interesting though. I'll see what I can find. Do you have a link?
Re: Modulating a Laser Beam
05/04/2007 2:01 PM
How about the micro-mirror chips they use for digital projection TV? You could attenuate the average power by pulse width modulating the beam.
05/04/2007 2:07 PM
Cool! Thanks! I'll try try to find some info---
05/04/2007 2:09 PM
I think TI makes them.
05/04/2007 3:16 PM
TI DMD 1100 chipset for projection TV: $6000 usd
<sigh> oh well..
http://www.tyrexsales.com/integrated-services/dmd-discovery/1100-controller-board/
05/04/2007 4:14 PM
try www.dlp.com. $6K is more than these TVs cost.
05/07/2007 8:33 AM
Well that's what I thought!
I searched, but I don't think that the .98 DLP chip is available to the public yet.
Canada - Member - New Member
Good Answers: 11
05/05/2007 12:26 AM
You cannot use AOM, can you use EOM?
You say other than mechanical, is it because of speed?
If you go piezo, you could either make a shutter or beam steering mechanism/trap that can go that fast. This could be not too costly or complicated.
For a more esoteric solution, there are electro-absorption modulators, but not much info on products is available but I believe your laser would need to be in a waveguide/fiber.
05/07/2007 10:24 AM
Quote>"You cannot use AOM, can you use EOM?"
Expense is mainly the reason. This is a personal project; non-funded.
05/05/2007 6:53 AM
Yes indeed there are several methods.
The simplest and least expensive is to start with a Laser Diode. A Laser Diode is a low voltage device and its light output can be varied from on to off and any thing in between. Do NOT drive it with a voltage source. A variable current source is the proper method. Laser diodes come in a wide range of wave lenghts (colors) and output powers. CAUTION You can damage you eyes. Please be careful. If you want a visable light choose a wave length 635 - 650 nanometers. These are available in a wide variety of wave length and power and are not very expensive. Laser diodes are very sensitive to static electricity, so use care when handling. Green are also available but more expensive. Jameco is one of many sources. Google will also help you find lots of info on both Lasers and the drivers. Many of the IC manufacturers make the drivers. There are also simple circuits that you can build using basic electronic components.
LCDs and Pockel cells used in conjunction with polarizers is an other way to modulate light but this is much more expensive.
Look around a bit and / or post quiry if you need more info.
Good Answers: 120
05/05/2007 7:15 AM
This is typically done with a polarized beam and a kerr or pockels cell.
http://en.wikipedia.org/wiki/Pockels_effect
http://en.wikipedia.org/wiki/Kerr_effect
Per Ardua Ad Astra
05/05/2007 9:56 AM
A revolving faceted mirror may be the answer for you as a quick and simple method. Only allowing the laser light thru a single small hole after reflecting off each facet.
Early laser printers "scanned" the semiconductor drum with such a device years ago (20?) to form the characters to be printed. So you may get the mirror and the motor from an old type Laser printer that is being junked. Checkout laser printers from StorageTek (Siemens Built), Siemens and IBM - to name but a few....
Even building one yourself should not be too difficult......
Good Answers: 88
05/06/2007 12:02 AM
Two similar technologies exist which allow for externally modulating a CW laser beam into the high MHz region: Pockels and Kerr cells. Pockels cells typically use a solid potassium-deuterium-phosphate (KD*P) crystal to modulate the beam's polarization angle, after which the beam is then passed through a stationary polarizer, amplitude- modulating the light. Kerr cells use a liquid dielectric (often nitrobenzene) to perform a similar action, but require higher voltages.
The polarization angle of some lasers rotates over time. If you are using a gas laser, you can fix the polarization to a constant angle by immersing the laser in a fairly stiff, constant magnetic field.
I used a similar setup in high school to transmit a high-fidelity television signal over a HeNe beam for a distance of two kilometers.
Apart from externally modulating the laser light, as above, semiconductor lasers can be modulated directly.
05/07/2007 10:32 AM
Thanks You-all, I guess the most practical thing to do is break down and buy a module with analog modulation. I think I can get a Lasever 532nM 100mW for <400usd.
That'd cost less than a AOM
Thanks Again!
Steve
Good Answers: 120
05/07/2007 10:49 AM
I think I have an old laser modulation until on my shelf from a project that I can donate to you. You will have to search for the specs. From a French company.
I will PM you
Per Ardua Ad Astra
05/07/2007 10:52 AM
Thanks!!!
Register to Reply 17 comments
Andy Germany (1); aurizon (2); bhankiii (3); BrainWave (1); gigaconcept.com (1); steve-o (7); user-deleted-13 (1)
You might be interested in: Laser Beam Analyzers, Laser Processing Equipment
