Previous in Forum: Troubleshooting of Flame Detector of Firetube Boiler   Next in Forum: Naming of Parts
14 comments
A Rant About the Metric System
02/16/2012 5:51 AM
I ordered some plastic sheeting cut to size 1195mm wide.
It arrives and it's too small.
I'm willing to believe I've screwed up, I check with a tape measure and find I'm unable to read off a simple length! Why? Because of the incorrect implementation of the damn system. We should have metres or millimeters, but no the tape has this daft numbering of centimetres...
I read off 10 at some point... groan, it makes no sense it should say 100(mm) or .01m
Or maybe we should have complete confusion and use decimeters too.
We have a system which is working (in common use) to base 10 in some points and base 100 in others. Joe public (and Mrs Cat) likes centimeters.. I hate the damn things with a vengeance, and no one uses decimetres.
Oh and the plastic sheet?
They'd cut it wrong 1095... I rest my case.
Good Answers: 88
Re: A Rant about the Metric System
02/16/2012 6:29 AM
How about 11/16cm or 18/32mm? It'd serve'em right Del, no?.(lol) S.M.
02/16/2012 7:23 AM
I E-mailed a picture of the sheets with a tape alongside.
The company has arranged replacements, very swiftly.
Re: A Rant About the Metric System
02/16/2012 8:55 AM
Move to the US.
We use inches, and virtually everything has components that are metric. As if working on the newer cars wasn't enough of a pain in the arse, the nuts and bolts are a mismash of standard and metric.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
02/16/2012 9:07 AM
Am I the only one to notice that Del has the same "Powers of 10 /decimal point location" problem I do?
10 cm is indeed 100 mm....but it is 0.1 m, not 0.01 m as Del claims. The problem, methinks. (1 cm = 10 mm = 0.01 m)
I have two solutions to this problem:
  1. Write down the numbers as they appear on the tape...and then sit down with a nice glass of water (honest) and do any conversions necessary.
  2. Measure the thing again in inches and convert to make sure it's at least close!
Now repeat with calculating the volume in litres of a cylinder 12" DIA x 305 mm long.
Now did you really want the 1195 mm width? Or will they be sending that and you actually want something else?
Is the a dust cover for your lamp shade or are you building/repairing a greenhouse?
Chaos always wins because it's better organised.
02/16/2012 10:53 AM
Ah! The sheets of plastic are for tertiary glazing on the BIG double patio doors in our 'sun lounge' (single storey extension which runs along the back of the house, on which stand my solar panels).
It's a try out on the two fixed panes, the sheeting will be fixed with self ahesive steel tape on the window and self adhesive megnetic tape on the plastic sheet (or the other way round in the Southern Hemisphere).
Of course the weather will be lovely and warm now I'm doing this.
If it works, I could do the same on the outside of the sliding panes.
I'm also planning to add some insulation to the ceiling too, install new gas boiler, replace all old radiators and generally upgrade the CH for next winter. Also planning to run water and a foul water drain to the other extension room in preparation for adding shower & loo for when I get old and decrepit (hopefully a while yet)
Good Answers: 75
02/17/2012 5:07 AM
It works well. We had wooden framed single glazed french windows onto our veranda when I was a kid. Dad used to bring home the shrink wrap they wrapped the cigarette packets in and hairdryer it to the window frames. Kept the draughts out a treat (couldn't open the doors all winter though!)
02/16/2012 9:24 AM
Yeah centimeters seems a bit odd anymore, at least to me. Most 'engineering' metric units are in divisions of 103n (... 10-6, 10-3, 100, 103, 106...).
I recently bought a optical component, a grating, for measuring spectra. The software supplied is set up for angstroms. Ångstroms? (10-10 m) Not nanometers (10-09 m)? I didn't think anybody used angstroms anymore, but I guess there is still a pocket of astronomers who haven't abandoned this obsolete and ungainly unit. It might seem like a simple thing, since its a straightforward conversion by ÷10, but I have years of mathcad routines that accept data in nanometers, and unless I can fiddle with the software to give results in nanometers, I'll have to be careful to modify every mathcad routine to ensure it's calculating in nm and not spurious tens of nm.
Good Answers: 75
02/16/2012 10:16 AM
See, now. That's the problem. And three is such a wonderful number base.
You have answered my puzzlement on the passing of angstroms, though. Thanks.
Good Answers: 137
02/16/2012 12:57 PM
Astronomers using angstroms? They're more likely to use lightyears or parsecs. Angstroms are more for particle physicists, 1 Å is approx diameter of a hydrogen atom.
02/16/2012 3:14 PM
Stellar spectra. For years Astronomers have used Angstroms to describe the wavelengths of the spectra they measure, and I suppose there is an inertia there they haven't overcome.
Parsecs aren't used as much anymore since there aren't very many astronomers (as a percentage of all astronomers) doing positional astronomy.
Good Answers: 137
02/16/2012 4:00 PM
OK fair enough. Now I come to think of it, when I was a student we had wavelengths of say 5000 angstroms (visible light) where now we'd say 500 nm.
02/16/2012 2:31 PM
I hate the Metric system, too.
Back in the 1970's, 0r 80's, someone, probably a tool supply company who had members of the US Congress on their payroll forced us to go to the metric system, sort of.
The out shoot of this brilliant idea caused every mechanic in the USA to go buy a complete set of wrenches for metric hardware. (Finding metric screwdrivers is always a hassle)
But wait, there's more. On American made vehicles, running changes were made so that you'd have to have both sets of tools at hand to work on any thing.
I don't work on cars any more, but I'll bet it is still a big metric/SAE cluster F.
02/16/2012 3:17 PM
Metric screwdrivers? Yeah, almost as hard to find as metric crescent wrenches.
Good Answers: 75
02/17/2012 5:32 AM
In the UK we have some Imperial legacy stuff, needing imperial tools, UK metric standards (10 mm, 13 mm 17 mm, 25 mm generally) and European (German?) metric standards (10 mm, 11 mm 12 mm, 15 mm). Now the car companies put star drives on many bolts...changing the patterns as soon as the aftermarket catches up.
It's no wonder the lads have toolboxes taller than they are!
When you find the metric screwdrivers, can you grab me a left-handed one, please?
Register to Reply 14 comments
Codemaster (2); English Rose (4); kramarat (1); lyn (1); SimpleMind (1); Usbport (3); user-deleted-1105 (2)
