Previous in Forum: Control Valve   Next in Forum: Flow Measurement Under Vacuum
Can Someone Check This for Me?
02/18/2012 10:03 PM
Hello All, Could someone tell me if i am right or wrong on these,,, The S value for a fluid flowing in a 4 inch pipe is 0.1430. Calculate the diameter of the orifice to be used if the primary device is a flow nozzle,, I came up with 1.52 in. Seem OK ? Another,,, Calculate the permanent pressure loss, in inches of water, of an ASME nozzle having 50 percent B ratio. The differential pressure is 100 in. of water,,,,, i came up with 65, sound right?
Re: Can Someone Check This for Me?
02/18/2012 11:37 PM
What's S value mean? What is the pressure? what is the gpm required? What is the length of hose? What is the B ratio? Differential between what and what? what type of gas??
02/21/2012 3:05 PM
OK, took the test and had them right, Thank You for the help.
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
02/19/2012 11:46 AM
The first problem as stated has a LOT of missing information. We have no idea what the flow measurement range is, or the expected DP to be developed by the flow nozzle, or even the fluid type. I'm not even sure what "S" value means (specific gravity???).
For the second case (the ASME nozzle), I can only imagine that somewhere in your course materials is provided either a formula or a chart plotting permanent pressure loss for ASME nozzles. I found a site by Imperial Flange and Fitting company giving a chart of permanent pressure loss versus beta ratio with a figure slightly less than yours of 65 (for 100" WC DP). I'll let you do the Googling necessary to find this site.
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
02/20/2012 12:48 PM
Register to Reply 4 comments
lyn (1); SolarEagle (1); theo2 (1); tonykuphaldt (1)
