Previous in Forum: Loadflow Power System with Simulink   Next in Forum: Insulation Class F/B
I Have Questions, I Want You Check My Answers
02/20/2012 1:15 PM
Hi all ... I have questions, I want you check my answers My answer : Q 1 )The usual procedure for obtaining a test-retest is to give the same test to the same group on two different occasions, usually within a short period of time. Generally, the shorter the retest interval, the higher the because within a shorter span of time there are fewer reasons for an individual's score to changeCan be tested when we administer the same test to the same sample on two different occasions. This approach assumes that there is no substantial change in the construct being measured between the two occasions. The amount of time allowed between measures is critical. We know that if we measure the same thing twice that the correlation between the two observations will depend in part by how much time elapses between the two measurement occasions. The shorter the time gap, the higher the correlation; the longer the time gap, the lower the correlation. This is because the two observations are related over time -- the closer in time we get the more similar the factors that contribute to error. Since this correlation is the test-retest estimate of reliability, you can obtain considerably different estimates depending on the interval.• The most common La is : Volume
Q2 ) The themistor … Because It can convert the current and the range and accuracy is suitable
Q3 )
Ro=120 Vs = 5 V Q = 0.0039DR1 = Rt - R0 = R0.tVo = vs (DR1/R1+R2) =120(0.0039X120)Rt= 56016= (120 - 5 (-16)/170.16 = 0.7 V
Re: I have questions, I want you check my answers
02/20/2012 1:24 PM
Looks good to me. I've checked all your answers.You might want to edit this to include the omitted words here," the shorter the retest interval, the higher the...... because within a shorter span........".
Re: I Have Questions, I Want You Check My Answers
02/20/2012 2:37 PM
why the picture is not here ... ??
and please check Q4
http://store3.up-00.com/Feb12/fHm56592.jpg
02/20/2012 2:43 PM
You didn't answer Q4.
Sorry, I can't help any more.
Bye.
02/20/2012 2:43 PM
Hi sir ..
Q 1 is correct and is the
lake of R is volume ...
Q2 :It convert the current to electrical that which I meant ... Is this full answer ???
Q 3 : Is correct ?
Q4 : Just I want know potentiometer float is sensor or signal processor ?
02/20/2012 4:59 PM
where are you ?
02/20/2012 11:38 PM
For Q1 is voulme is most coomom lake
Q2 : is thermocouple
Q3: votage = 0.0194
Register to Reply 6 comments
