Dear Friends
Reduce Ozone in air as much you can as even at 70 parts per billion of air volume it is dangerous. Do not hold on for longer period in high Ozone area. It directly affects your brain neurons and memory for ever and may make one very forgetful.
Where you may find greater Ozone.
Ark welding area - use air blowers if you are a welder
UV lamps for adhesive solidification - do all that in a fume hood and with exhaust
FL lamps - Use UV filters and monitor UV level
Living in Australia - Too much UV in air so keep in door in peak day time in closed doors and walk in morning and evening
Dust remover ionizer- If you are using a dust remover ionizer in your room which has ion generator by spark then lock the room when you switch it on and enter the room after switching it OFF for 30 minutes of more. Keep some Ozone level alarm.
Water bacterial Ozone killer - most of the water purifiers use Ozone as bacteria killer. Heat the water to let the ozone out or buy one which has heater after ozone exposure stage. Dissolved oxygen may have been converted into large amount of Ozone.
Factories using Ozone - Insist on Ozone alarms and never switch them OFF
Finally good luck and don't get scared but take precautions.
I am for your good health. Take care.
Read more
http://www.epa.gov/sab/pdf/casac-07-002.pdf
I think we need a separate topic related to health and safety engineering and may also include environmental engineering issues and solution. We are missing something very essential area of engineering. Let me hear from you all. This is for behind the CR4 screen.
Shyam
