Previous in Forum: Hydro Generator Setup   Next in Forum: Open Source Civilization Starter Kit
8 comments
Hydro Power for Trout Hatchery
02/22/2012 7:11 PM
I have been looking for a turbine generator that will fit a set of ponds that have been established for raising and sustaining trout ranging from hatchlings to two feet in length. The farm has a set of four race ways each with 2 feet of head separating them. It would be pretty inefficient to install pumps in this location but there are 2 very large ponds with a portion of a river being diverted to flow through it. The flow rate through these two ponds has been calculated to be 400 GPM. There is a 15 ft. waterfall separating these tow ponds that a turbine could be placed at the bottom to collect power the only thing is that flooding is an issue in this area and that location could be susceptible to damage.
There is a drain pipe at the last pond that has the 400 GPM flowing through it. the suction on this pipe is tremendous due to the 20 ft. of head that it drops to return to the river. Again a turbine cannot be placed at the exit of this pipe due to damage when the river is at flood stage. However I have been researching Kaplan turbines and vertical axis turbines that work off the suction from a similar style pipe. Unfortunately these style turbines are either gigantic or small on the order of 300 watts.
My question is does anyone know of a turbine or manufacture of turbines that makes a generator that will fit this application.
Another option is to take a vertical pump like pictured below and run it backwards as a generator since there are plenty of this style pumps that should fit the application. I have no experience with doing this and am not sure the details involved in doing something like this.
Any help would be greatly appreciated or just a point in the right direction.
Re: Hydro power for trout hatchery
02/22/2012 7:40 PM
Welcome aboard. Great starting thread.
Here's a little food for thought. I'm not sure how it would relate to the fish, but it's a start. Very simple design.
http://www.youtube.com/watch?v=w2kxu_5hNTk&feature=related
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: Hydro Power for Trout Hatchery
02/23/2012 5:39 PM
There are many larger micro turbine available ( a random link below).
http://www.hydro-turbines.com/id30.html
But it sounds like your real issue is how & where to install it in the best location without the risk of damage or loss during floods.
My suggestion would be to create a Small "Plant Room" formed from concrete and anchored in place to piers at the best location for performance designed as an inverted cave or bubble with either a water tight door (I wouldn't do this) or the better option no door and all access from below. This will allow the generators and controlls to stay Dry in the case of a flood and give you the best performance for the move you spend.
Regards,
Sapper.
p.s. great application, power some or all of you fishery from the run-off.
It's all about the Boom! - MythBusters
02/24/2012 2:59 AM
You can try the vortex turbine. works well for low heads and it's quite low tech.
http://blog.hasslberger.com/2007/06/water_vortex_drives_power_plan.html
The time is ......now
02/27/2012 6:46 AM
Interesting that you mention this. I have visited the site that Franz Zotloetter built and saw it in action.It works very well. I had looked for the distribiution rights to this but was difficult. Will look again maybe in future. Absoloutely no fish kill or injuries in this method. You need 1cubmic metre per sec flow rate and 1 metre fall.
You see things; and you say, 'Why?' But I dream things that never were; and I say 'Why not?' George Bernard Shaw.
Good Answers: 153
02/24/2012 4:38 AM
You have not made it clear if you allow the fish to migrate freely to the river. If this is the case, check out Pitlochry Hydro Power station in Scotland where they have a fish ladder installed.
Good Answers: 179
02/24/2012 9:32 AM
Some very good suggestions regarding acceptable pumps and protecting the generating room.
But, have you thought about protection of the hatchlings, as you may end up with fish kills if you do not mitigate their movement into the intake screen and subsequently the penstock, no matter what type of turbine-generator you select and install? This is a very significant concern which you must address, possibly with the installation of a series of bar trash racks followed by an acceptable intake screen. Also, I suggest that you limit the maximum water velocity to less than 1 feet per second (FPS) at the intake screen so that fish are able to swim away from that structure.
02/24/2012 10:42 AM
The Archimedes turbine is a really cool idea. There is actually a location that this would work perfect for although I haven't had time to research these turbines yet. As well as what it takes to install them. I might have to get ahold of an industrial engineer as it appears lots of concrete needs to be poured for this setup.
As for the issue of the hatchlings they are all kept in an indoor facility that has tanks with water flowing through it from ground water. They are kept indoors until they are of size to be introduced to the outdoor raceways which have screens to keep them from swimming into the river. Once the juvenile trout are large enough they are moved to the large ponds where rebar screens keep them from exiting.
In terms of powering the trout hatchery the actual costs to run are very small. The large expense is the heating cost for the turkey farm that is located on the same farm. The heating expenses for the poultry farm are in excess of $46,000 annually.
02/25/2012 10:48 AM
If you can simply install a well point(s) attached to a 2" poly pipe(s) and run it down at least 10 feet vertical from the highest point one of the tanks to a pelton wheel generator (or 2 or 3) you can buy a commercial generator without having to rig up anything or build an expensive tank.
I have a 1 1/2" pipe 50' long with a vertical drop of only 12' that generates 65# of pressure frm my waterfall in Tennessee. A 2 foot long sand filter well point lays in a crevice in a pool in the waterfall and runs even in sub-freezing weather because the flow of the creek keeps the water from freezing.
http://www.youtube.com/watch?v=Hq5KCVPU_EE&list=UUZE4sstQBE7CJAGn4LDcTXA&index=1&feature=plcp
Register to Reply 8 comments
129CBRider (1); awdturbo04 (1); CaptMoosie (1); irelandeng (1); jhhassociates (1); kramarat (1); nikolay (1); Sapper (1)
