In addition to Tornado's comment,
these are also helpful:
Forward reversing starter: It is required where the motor need to rotate in both
direction such as the MOV (Motor Operated Valve). MOV is used to close or open
the valve operated by motor. In this case, motor rotates in one direction for
opening the valve and opposite direction for closing the valve.
Star Delta Starter: It is required where
the motor starting current needs to be reduced (approximately 1/3rd) and the initial starting torque
of the load is less (approximately 1/3rd).
- MS
