Previous in Forum: Turbine   Next in Forum: 5KVA-50KVA Organic Rankine Cycle Turbines and Heat Exchangers
Work Done in Turbine
02/24/2012 5:28 AM
Which condition work done will be maximum in turbine i.e 45kg/cm2 and 540 degree or 140kg/cm2 and 540 degree
Re: work done in turbine
02/24/2012 5:47 AM
That would depend on the exit port conditions in each case, Uncle.
Good moaning!
Re: Work Done in Turbine
02/24/2012 6:41 PM
Which do you think it is? And why?
02/25/2012 1:33 AM
Specific heat capacity of steam changes with temperature and pressure. For the improvement of efficiency of turbines, superthermal, even critical and ultracritical thermal power plants have been developed. Just because of higher specific heat capacity of steam at high pressure and of-coarse there are many other advantages.
There is no direct relationship between temperature, pressure and the specific heat capacity of superheated steam. There is, however, a general trend towards an increase in specific heat capacity with increasing pressure at low degrees of superheat, but this is not always the case
Typical value range for ref:2.0 kJ/kg °C at 125°C and 1.013 bar a (0 bar g)
3.5 kJ/kg °C at 400°C and 120 bar a.
Hence the work done by the same amount of steam will depend on the specific heat capacity of the steam.
02/25/2012 7:08 AM
ON the FIRST CONDITION
Reply Score 1 for Off Topic
Crabtree (1); lyn (1); Mukesh0861 (1); thinkhigh (1)
