Previous in Forum: Stabilty For Motors   Next in Forum: Help to Identify This Schematic Symbol
Siemens 7SJ602
02/24/2012 2:03 PM
Two Binary inputs are used (i.e. B11 and B12 ) in siemens 7SJ602 Relay for motor/feeder protection. In manual these binary inputs are stated to be used as trip circuit supervision....but how actually they are coming in role?????
Pathfinder Tags: electrical siemens
New Zealand - Member - Kiwi
Good Answers: 29
Re: Siemens 7SJ602
02/24/2012 2:25 PM
Check out http://siemens.siprotec.de/download_neu/devices/7SJ602/Catalog/7SJ602_Catalogue_V35.pdf
At the bottom of page 11 there is a connection diagram that should help you.
paulusgnome
Re: Siemens 7SJ602
02/25/2012 10:34 PM
It is a numerical relay. Binary inputs/outputs are programmable, either via keypad on front panel or via Siemens DIGSI software (PC connected with front port of relay). In the section of Trip Circuit Supervision in relay manual, the inputs BI1 and BI2 are shown just as example.
Check the relay manual for default or factory programming of these inputs. You will need password to change these.
Register to Reply 2 comments
