Previous in Forum: Data Of Addendum Modified Gear   Next in Forum: Shear Strength of Gold
Carbon Material (SA516-70) to be Normalized and Tempered
02/27/2012 12:18 AM
i want to increase the yield strength of Sa 516 to min 450 mpa
what process i have to follow . normalizing or hardened & tempered
& if anybody have heat treatment chart. pls share
Good Answers: 34
Re: Carbon Material (SA516-70) to be Normalized and Tempered
02/27/2012 3:33 AM
Increase to.......?
SA 516 -70 Tensile strenght 485 to 620 Mpa
02/27/2012 3:43 AM
SA516 Gr 70 yield strength is 260 Mpa. i want to increase the value of yield strength
up to 450 Mpa by means of heat treatment.
Good Answers: 104
02/27/2012 4:59 PM
Is this a lab experiment or real-world case? Why would you want to do this? Just interested.
03/02/2012 5:46 AM
There is an intersting case study here for the effect of heat treatment on physical properties of carbon steel. I am not sure it will serve your purpose but it will give some details to understand the actual results of heat treatment.
03/02/2012 7:27 AM
thank for the information. it is not a case study, i want to increase the yield strength of mtg bracket plate to take the shear load on the bolts, but then i decide to increase the thkness of the plate.
bigg (1); Mukesh0861 (1); shaktishen (2); Whitephone (1)
