Previous in Forum: Carbon Material (SA516-70) to be Normalized and Tempered   Next in Forum: Discontinuity Stress-Knuckle
16 comments
Shear Strength of Gold
02/27/2012 4:02 AM
Hi there.
is anyone know the shear strength value of aurum (gold)?
i have googled but come to zero conclusion. is it there is no specific value for it?
-- i'm going to use this value to determine press load for stamping of gold flat sheet --
Re: Shear Strength of Gold
02/27/2012 4:24 AM
OK send me some samples and I'll do some measurements for you
Seriously though:-
http://en.wikipedia.org/wiki/Gold
Has shear modulus = 27 GPa
Does that help?
02/27/2012 10:05 PM
Yes I come across the modulus, the modulus is shear stress vs.shear strain (if i'm not mistaken)...still there is no shear strength
by the way...i myself doesnt own any sample!
02/27/2012 7:21 AM
If you are punching, shearing, or cutting it, then the shear strength would matter.
If you are bending it, rolling it, or die-stamping it, you need to deal with bending, tensile, and/or compressive strength.
02/27/2012 10:34 PM
in one website (forget what its name), theoretically the formula :
i.Stamping without shearing :
perimeter x material thickness x shear strength = required tonnage
ii.punching:
required tonnage for stamping x shear factor
both need shearing value...where should i get it..?
Good Answers: 179
02/27/2012 8:28 AM
The answers that you seek will greatly depend on the Karat of the Gold......how much of an alloy it is.
02/27/2012 10:44 PM
yes, it should be...but cant i just get an approximate value for preliminary calculation using above simple formula, just to have an idea? do you have any figure?
Good Answers: 146
02/27/2012 11:14 AM
Young's modulus of elasticity values will vary depending on the metals used in the alloy. Gold is typically alloyed with other metals to increase its strength and hardness, since pure gold is already remarkable for its high ductility and malleability. Some examples are given here:
http://www.keytometals.com/page.aspx?ID=CheckArticle&site=ktn&NM=230
Also note that the strength of any gold alloy will vary the most, depending on whether it is annealed or hardened - see the chart at the bottom of the page. The usual process is to anneal the gold sheet before stamping. The process of stamping will harden the metal to some extent, but additional treatments may be required if the end product is to retain its shape without deformation.
incus opella
02/27/2012 10:46 PM
thanks for the link...it does enhanced the knowledge but still doesnt have any shear strength value given
Good Answers: 19
02/27/2012 11:59 PM
Can you first detail why is this so important. If it is just from your personal knowledge then it will be a waste of time.
02/29/2012 4:21 AM
my team want to buy a hydraulic press to stamp a gold sheet whether making it into coin or souvenir. i have ask some press machine supplier, they require us to provide what exact press tonnage we want.they do suggest some tonnage range but i want to know exactly how they determined.so i googled and find in one website the formula which require shear strength value to be use to have the pressing tonnage.we can find the value for steel but not gold.
i dont know whether this is so important or not but i'll much appreciate if i can have the answer.
Good Answers: 19
02/29/2012 4:48 AM
Send them the sample and tell them this is what you want to do.
I happen to drive back & forth Toronto to NY. On way at Coffee Stops in USA Highways, there are manual (with handle) machines that takes in your dime and stamp out any engraved photo and bringing out the coils in an oval shape for souvenirs kids would like to have. I do not find any complexity in this machine simple-manual with hand-wheel.
Send them the samples and ask them what you want.
Good Answers: 19
02/29/2012 4:50 AM
coins in oval shape ( the dime comes out as)
02/29/2012 7:57 AM
The press operation being described is known as "coining," and it takes more force than punching, shearing, or bending.
Good Answers: 146
02/29/2012 12:38 PM
Well... stamping a cut blank is "coining", but cutting the blank itself is "blanking" (not punching). These are two distinct operations requiring a different machine. There are also several steps between blanking and coining, in which the surface of the blank must be finished and polished before coining.
The OP isn't clear whether they intend to cut their own blanks and then stamp them, or whether they have idly assumed that a coin is made in a single blow operation.
It also isn't clear to me, why someone with the resources to engage in a mechanized gold coin minting operation would be asking for free information on the internet, instead of engaging the professional services of a goldsmith.
incus opella
Good Answers: 183
02/29/2012 11:55 AM
Consider all comments with respect to variations due to alloy type. If you have the yield limit for the alloy divide by 3^0.5 and you obtain the approximate value for the shear limit.
Good Answers: 146
02/29/2012 12:39 PM
GA.
incus opella
Register to Reply 16 comments
affan zubayr (5); artsmith (3); CaptMoosie (1); ducon (3); nick name (1); Randall (1); Tornado (2)
