Previous in Forum: Cable Sizing   Next in Forum: CAT 32 DVR Failure
13 comments
Dry Type Transformer Failure
02/28/2012 8:53 AM
I have a 50kVA dry type transformer which had failed, with rating:
1. Input (LV, primary winding): 400V, 72.17A
2. Output (HV, secondary winding): 21.5kV, 1.34A
3. Average Output usage (single phase, DC): 24kV, 1.35A
The failed area was found to be the HV winding, where arcing and sign of localized overheating was observed . Calculations showed no overload to input or output. Observation of the other similar and unaffected transformer also showed same overheated marks on the upper portion of the HV winding.
What would have cause the overheating? probable cause of the failure?
Re: Dry Type Transformer Failure
02/28/2012 9:57 AM
OK. I'll start. I'm guessing a >+10% voltage excursion event on the primary winding.
Is there a prize for getting this right, BTW?
Good moaning!
02/28/2012 10:05 AM
Good morning.
How do you get the >10% voltage on the LV primary side?
My calculation: P=EIx1.73; E=400V, I=58A
Thus, input power about 40kVA, less than normal rating 50kVA.
02/28/2012 10:18 AM
I don't get a >+10% voltage on my windings. I don't know anything about your power source so any surge in voltage will be on your equipment.
Good moaning!
Good Answers: 44
02/28/2012 11:36 AM
It's funny how transients happen so damned fast!!!
Good Answers: 181
02/28/2012 11:11 AM
From past experience dirt springs to mind. What sets of as a slight leakage soon builds up until flashover occurs giving you the burning you see now.
02/28/2012 1:00 PM
Probable cause of the failure?
Voltage spike damaging inter-turn windings of HV coil resulting in eventual (not necessarily instant) arc/overheating and damage to HV winding within a localised part of the transformer.
Could also be a transformer manufacturing defect (or a combination of the two).
Good Answers: 102
02/29/2012 1:45 AM
Your records showed no sign of any overload so that is not the cause
What would have cause the overheating? ...Inadequate cooling most likely if the above is really true.
The failure is the result of a process culminating in an event. Step by step and your other trafo looks like it is on the way out too.
Look carefully at the environment. Do you trust the manufacturer's rating claims? Did some one omit a derating factor at the onset?
02/29/2012 2:12 AM
Have your checked the inrush (start-up) current for the equipment being powered. We recently have found that some of the equipment installed on our site has higher inrush currents than specified by the manufacturer of the equipment. If the inrush is higher than the transformer rating this could be what's caused your problem. With our problem the inrush was found to be approx 4 times the nominal rating of the transformer and at present we are lucky that it has not burnt out.
02/29/2012 9:35 AM
It sounds more of a lightning strike, than over load, and the taps on the primary side...
Good Answers: 27
02/29/2012 10:53 AM
The most common cause of failure on dry type HV transformers are insulation break downs on the magnet wire and inter-winding insulation. Deterioration of conformal coatings triggered by the combined accumulation of dirt and moisture. Heating is the after effect when HV arcing starts to develop due to the deterioration of this insulation.
vsar
03/02/2012 3:37 AM
Failure may be due to following reasons:
You have mentioned,' Average Output usage ( single phase, DC ) : 24kV, 1.35 A. That means the output AC voltage is converted to DC voltage for some special application( not mentioned ). If IGBTs are used for DC conversion, high volatge pulses may hit the HV windings and in effect interturn failure of HV windings may be happened. Due to interturn failure , localised heating may be occured and ultimately insulation may be damaged and trafo may be failed.
If there are harmomics in load side and fed to trafo, loaclised heating and failure of insulation may occur.
If the condition of epoxy insulation are not good,i.e.,there are pores/ air pockets in epoxy insulations, partial discharge at high voltage may occur and inturn localised heating and failure of epoxy insulations.
If photographs are available and nature of load or application in details are availabe, analysis of failure will be easier.
Thanks,
Manindra.
Manindra
03/05/2012 5:27 AM
This is a rectifier Transformer application the failure may be attributed to the high dv/dt causing the damage to the start of the winding.
The actual reasons of the failure can only be commented after seeing the failure and kind of insulation scheme used for the transformer.
1.The class of insulation on the conductors?
2. During the design what was the stress level on the insulation?
3. What are the harmonics level Consideration during the design?
4. Background of Application?
I have got these questions from our technical manager, if you answer those, we can help you more. You may write to *
Regards,
Sujit
DuPont Nomex Team
*CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Good Answers: 11
03/05/2012 11:53 PM
My opinion is failure was caused by corona. (partial discharge)
The overheating was caused by a partial short where the corona ate through the insulation.
If when you disassemble the coil, the insulation is eaten away in other areas of the coil, this is a sure indication that there was corona in the coil.
Register to Reply 13 comments
Carl Pugh (1); Crabtree (2); cuba_pete (1); danny_su (1); dvalnrd (1); Gersh (1); jack of all trades (1); manindra (1); sujit oommen (1); TonyS (1); vsar (1); Wal (1)
