Previous in Forum: Air Chillers for 3rd and 2nd Stages of Air Compressor   Next in Forum: Performing Stress Analysis on Pole Bunk
What Are Advantages and Disadvantage 2 Pass Flow and 4 Flow Pass Heat Exchanger?
02/28/2012 8:55 AM
hello dears,
plz tell advantages and disadvantage of 2 flow pass and 4 flow pass heat exchanger and also tell that who is more efficient heat exchanger 2 flow or 4 flow with reason?
Re: What Are Advantages and Disadvantage 2 Pass Flow and 4 Flow Pass Heat Exchan
02/28/2012 11:26 AM
4 pass coolers are compact as compared to 2 pass coolers but cooling achieved in 2 pass cooler is more then 4 pass cooler.
In 4 pass cooler, media pass velocity reduces considerably so more chances of silt formation.
4 pass coolers are suitable for small requirements and cooling water requirement is less as compared to 2 pass coolers.
Re: What Are Advantages and Disadvantage 2 Pass Flow and 4 Flow Pass Heat Exchanger?
02/28/2012 2:44 PM
The number of passes depends primarily on the desired velocity and pressure drop through the heat exchanger. Greater velocity ordinarily leads to higher K factor, but also to greater pressure drop. There may be some minimum and maximum desired velocities, for example to avoid sedimentation or erosion, respectively.
02/29/2012 3:15 AM
Size is important - especially if you want your wallpaper to stay up.
Good moaning!
02/29/2012 9:32 PM
There is good presentation on heat exchanger. This may help you understand.
Register to Reply 4 comments
Crabtree (1); Mukesh0861 (2); Tornado (1)
