Previous in Forum: Selection of Breaker for APFCR panel   Next in Forum: Please Help - Determine the Terminal Voltage
BDV Value
02/29/2012 4:06 AM
what is the bdv value of a one mva transformer ?
Re: BDV Value
02/29/2012 4:32 AM
You've read the user manual, haven't you?
You've rung the manufacturer, haven't you?
Now you're asking strangers. Why?
Good moaning!
Re: BDV Value
03/01/2012 2:11 AM
Sir I am not telling about a particular trs. On which basis it is calculated that for x trs. Y is the bdv value .ie rating of trs or voltage ratio of trs. Regards smruti
Re: BDV Value
02/29/2012 5:07 AM
Please have a look at the trafo datasheet........you will find the values there
Further these questions are very vague........these values differ from one manufacturer to other.....so u better be specific so that you yourself dont get misleaded.
Lastly........try utlising your resources first.......good for you in the long run
Re: BDV Value
02/29/2012 11:30 AM
Dear Smruti.sahu,
The di-electric strength of oil is expressed in terms of BDV. It tells the healthiness of the oil. If you are in India. Please refer IS 335 (for new Oil) and IS 1866 (for oil in service).
It depends on the working voltage and not the rating of the transformer.
Re: BDV Value
03/02/2012 8:12 AM
Thank u.
Good Answers: 170
Re: BDV Value
03/04/2012 7:37 AM
Transformers don't have a BDV Value. Only the oil used in transformers have. Then also it is not related to the MVA Rating of the transformer, but the voltage rating.
Register to Reply 6 comments
Crabtree (1); electricalexpert65 (1); kolokol (1); S SRINIVASAN (1); smruti.sahu (2)
