Previous in Forum: NGR Connections   Next in Forum: Secondary CT Leads
Tilt Position Indicator Sender Unit (Marine Outboard)
02/29/2012 5:56 PM
Folks I am looking to make a tilt and trim unit based on the CMC PT-130 which has a sender unit inside that sends the angle position of the unit back to a gauge on the dash. I am in the UK and am looking to source a sender that does this. Any ideas as to what sensor is needed to do the same job as that CMC use? George
Pathfinder Tags: cmc Outboard TILT trim
Re: Tilt Position Indicator Sender Unit (Marine Outboard)
02/29/2012 6:54 PM
These guys are good. They also have good forums for boat questions. I went ahead and plugged in UK for you. It looks like you need a sender also.
http://www.iboats.com/Boat-Parts-Accessories/dm/cart_id.364606977--keywords.trim%20gauge--session_id.646316656
03/06/2012 1:29 AM
Yes it is the sender I am interested in. I need to send the tilt position to a gauge which operates on a analogue voltage change between full up and full down position. A rotary or linear? waterproof to IPxx device? Low cost :-)
03/06/2012 6:25 AM
Did you ask the guys at iboats?
You have to register, but it's a totally safe site. The people on the forums are very helpful.
Register to Reply 3 comments
