Previous in Forum: Evaporative Air Cooler   Next in Forum: Enthalpy Differences
Pitch Circle Diameter Formula for Flanges
03/01/2012 12:28 AM
How to calculate quantity of the flange with 6 nos of holes.
Re: Pitch circle diameter formula for flanges
03/01/2012 1:48 AM
1. The quantity of flanges is completely unrelated to the number of holes.
2. There are no standard ANSI flanges with 6 bolt holes. Not sure about DIN flanges.
3. The pitch circle diameter is not generally calculated; it is looked up in tables.
4. For nonstandard flanges, calculations are by stress formulas and simple geometry.
Indonesia - Member - About Me
03/01/2012 2:26 AM
Good answer Tornado,,,
Good Answers: 137
03/01/2012 1:13 PM
Not in DIN flanges eitrher, or any standard I'm aware of. Bolt holes are always in multiples of 4. Not sure whether there's a technical reason for that, or just convention.
03/02/2012 4:16 AM
In Automobile and refrigeration industry, 2 bolt flanges and 3 bolt flanges with tongue and groove joints are also used. I am not sure of their standard but I had seen special valves and fittings in those two industries.
There may be some special service of specific equipment mounted fitting with 6 bolts. In gas turbines, this type of connections are made in low pressure services within the enclosers, where approach to the 8 bolts is not possible and 4 bolts leaves big space between the bolts, there 6 can be accomodated.
In 6 bolt flange PCD is twice the distance between two consecutive bolt centers.
Codemaster (1); dedek (1); Mukesh0861 (1); Tornado (1)
