Previous in Forum: Entropy and Work Done   Next in Forum: Brazed Plate Evaporator
Dead Bus Sync
03/02/2012 5:04 AM
I need a practical interpretation of the above please (I'm a Clankie so pls keep it simple)?
Re: Dead Bus Sync
03/02/2012 5:20 PM
Re: Dead Bus Sync
03/03/2012 2:11 AM
Nice one
Re: Dead Bus Sync
03/08/2012 12:01 AM
If you're refering to what I think you are, then it is simply the process of synchronising the sinusoidal waveform of one bus with another, (presumably the output from a generator). (bus is just a term that refers to the current carrying conductors of a distribution system). Synchronisation is done to prevent mechanical damage to synchronous generators. Connecting an offline machine to a distribution bus out of synch will exert a force on the shaft of generator and prime mover, proportional to the supply voltage and the degrees of displacement "out of phase". It can be quite devestating to a machine, often completely destroying it! I hope this helps.
An educated man is not necessarily knowledgable, but has the intellect to call upon his resources.
Re: Dead Bus Sync
03/08/2012 1:31 AM
Many thx, excellent help.
Register to Reply 4 comments
Anonymous Poster (1); Jack1959 (2); wopx8z (1)
