Previous in Forum: Magnetic Flywheel Turning   Next in Forum: Standart Transformer & Hermetically Sealed Transformer
Rotor Design
03/04/2012 11:16 PM
Hi, I'm designing an axial flux coreless synchronous generator for stand alone wind turbine. Rating is 500watts, 500rpm, 270volts. I've designed stator but I've one confusion is as follows: How does the specific magnetic loading varies with the thickness of rotor plate?
Re: Rotor design
03/05/2012 7:21 AM
It varies directly propotional to the inverse propotional wind speed from north to south.
Re: Rotor design
03/05/2012 10:11 AM
That only applies to generators in the northern hemisphere.
Good Answers: 213
Re: Rotor Design
03/05/2012 11:20 PM
You may want to give FEMM a try- a free 2D finite element analysis for magnetic fields.
Re: Rotor Design
03/06/2012 10:04 AM
http://www.google.ee/search?hl=et&site=&q=axial+flux+coreless+synchronous+generator&btnK=Google+otsing&oq=&aq=&aqi=&aql=&gs_sm=&gs_upl=&gs_l=
revealed
http://www.mojaladja.com/upload/elmotor/276_EWEC2009presentation.pdf
http://www.teces.si/prikazi.asp?vsebina=info%2Fobvestilo.asp&id=126&jezik=1033
... (i gess you can spot ***your graps somewhere (modifying the "Search" as you go (closer to***)))
... i thought i design a motor for my robotic experiment (but such not in active schedule ... so good luck with your own studies)
ci139
Register to Reply 4 comments
Anonymous Poster (1); ci139 (1); cwarner7_11 (1); lyn (1)
