Previous in Forum: Petroleum Storage Tank Spacing   Next in Forum: Head Room Clearance Required for Piping
13 comments
Coupon
03/05/2012 10:34 PM
i need to get a coupon to be used as alternative to A106 Gr.B
Re: coupon
03/05/2012 10:42 PM
That would come from the lot of pipe you want to have qualified, wouldn't it.
You might try Coupons-R-Us.com.
Re: coupon
03/05/2012 10:49 PM
thank you for your reply
i need a sheet metal to be used as a coupon but equivelant to A106 Gr.B
Re: coupon
03/05/2012 11:03 PM
Sorry, I can't help you.
It's a specification for pipe.
Re: coupon
03/06/2012 4:55 AM
Just cut 6in off a piece of A106 Gr.B pipe and use that. What's the problem?
Good moaning!
Re: coupon
03/06/2012 4:59 AM
thanks for your reply
but the thickness is very thin
so i am looking for a coupon with thickness of gauges not mm
regards
Re: coupon
03/06/2012 7:09 AM
Well, you could have said so in the first place.
Why do you need a coupon?
Good moaning!
Re: coupon
03/06/2012 8:18 AM
it will be used for lab. simulation
we will put the coupon at the same condition which the pipe A106 Gr B facing and check the corrosion rate
regards
Re: coupon
03/06/2012 8:44 AM
Now you make even less sense. Testing a coupon made by an entirely different process doesn't sound realistic.
You can check the corrosion rate on a piece of pipe easily enough with one of these:
Re: coupon
03/06/2012 8:59 AM
Please advice how to cut the pipe to this very small thickness
Re: coupon
03/06/2012 9:25 AM
What we have here, is failure to communicate.
Corrosion only occurs at the surface of the material. It doesn't matter if the sample is .01mm or 1mm thick. Material is not lost from the interior of the sample, only the surfaces.
Measure the specimen, immerse in fluid. After specified time measure again.
There is something we're not getting here.
Good Answers: 19
Re: Coupon
03/06/2012 9:22 AM
I am assuming you are looking for a corrosion test coupon, which water treatment companies will provide to very specific sizes and weights for measurement of corrosion rates, and for verification of the effectiveness of a particular water treatment program.
You could contact water treatment chemical companies with your request. You might also try to internet search corrosion consultants to see if they can offer advice where to obtain.
You might also internet search corrosion test standards to determine the dimensional requirements and have a capable shop machine the test coupons to your specific requirements.
Re: Coupon
03/06/2012 9:55 AM
THX
Re: Coupon
03/06/2012 9:53 AM
It is entirely possible that the A106 Gr.B material has already been corrosion-tested with the wetting fluid, which you haven't identified yet (and I am getting tired of this game), and that the results are available elsewhere. Try the Cole-Parmer materials compatibility database. Oh, you haven't specified the temperature either, which can be significant.
I'm off to talk to Michelle of the Resistance instead. At least I can understand what she is trying to achieve. <unsubscribes>
Good moaning!
Register to Reply 13 comments
Crabtree (3); lyn (4); mostafaalkholy (5); Ried (1)
