Previous in Forum: Input Impedance   Next in Forum: Data in ROM
Capacitive vs Resistive Touch. Why This Difference?
03/06/2012 6:03 AM
How capacitive and resistive touch screen works? what is the difference?
Also, why is it so that joystick (stylus) can be used with resisitive touch and not with capacitive touch?
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
Re: Capacitive Vs Resistive touch. Why this difference?
03/06/2012 6:29 AM
I'm guessing a little here, this not being my field.
A resistive screen reacts when its internal resistance (in a location or cell) is changed by the deformation of the screen. There are a number of materials whose resistance changes under stress - see strain gauges. Since only deformation is required, it does matter what does the poking: your finger or a stylus (a joystick is something entirely different) will perform equally well.
A capacitive screen works when the local capacitance is changed. This relies on voltage leakage through the contacting item. You are a reasonable conductor of electricity - and the values of the human body are known - the stylus is likely to be plastic and therefore will not conduct, thus will not promote a change in voltage.
I do hope this isn't a homework question and you're asking here because you don't pay attention in class.
Chaos always wins because it's better organised.
03/06/2012 7:18 AM
Hi,
A resistive touchscreen panel is composed of many layers, the most important of which are two thin, electrically conductive layers separated by a very thin gap. When finger, presses down on a point on the panel's outer surface the two metallic layers become connected at that point. This causes a change in the electrical current which is registered as a touch event and sent to the controller for processing.
A capacitive touchscreen panel consists of an insulating layer such as glass and coated with a transparent conductor. As the human body is a conductor, touching the surface of the screen results in a distortion of the body's electrostatic field, measurable as a change in capacitance.This causes a change in the electrical current which is registered as a touch event and sent to the controller for processing.
Hope you got answer.
Good Answers: 44
Re: Capacitive vs Resistive Touch. Why This Difference?
03/06/2012 11:47 AM
GA to Rose and CRSR...
I would only add that capacitive does not always require actual touch...mere presence close to the surface of a cd sensor can activate it. You will notice this on most personal electronic devices.
Good Answers: 27
03/07/2012 9:15 AM
I agree that at times one doesn't even need to touch the sensor and by just being near may trigger the switch. That has something to do with the existing humidity around that particular area..
vsar
03/06/2012 1:06 PM
Another aspect relative to the user is that the capacitive touch allows for a multi-touch effect allowing greater control and more varied input.
The resistive does tend to be more precise but alas, no multi touch. I always hoped for a precision device like a tablet to come out with both controls. A stylus for precision drawing or writing (used to be good at writing on the screen of my old Sony P910i) and the capacitive for the multi touch and ease of control.
Drew K
03/07/2012 6:01 AM
Stylus will work with resistive touch as it is only the pressure that is required to make the 2 films touch. Capacitive touch relies on the flow of current. Also why you can use resistive screens with gloves on but not capacitive. There are special stylus that can work with capacitive touch screens but it is special versus any hard pointy thing with a resistive.
Shawn
04/23/2019 3:30 AM
Top 10 Advantages and Disadvantages of Capacitive Touchscreen
When you use touch phones and POS devices, have you ever wondered why you could control them by touch? Yes, capacitive touch screen technology can achieve these functions. Now let's read the following article to learn about capacitive touch screen technology.
Do you want to know what the capacitive touch screen means?
A capacitive touch panel is a control display that uses the conductive touch of a human finger or a specialized device for input.
Capacitive touchscreen devices are typically handheld and connect to networks or computers via an architecture that supports various components, including satellite navigation devices, personal digital assistants and mobile phones.
Capacitive touchscreen glass is activated by human touch, which serves as an electrical conductor used to stimulate the electrostatic field of the touch screen. However, special gloves that produce static electricity or specialized stylus pens may be used.
How Capacitive Touch Panels Work?
Capacitive sensors are used to detect the position of the touch. Capacitive touch screens are designed to sense the human touch.
In capacitive touchscreen display, the glass panel of a particular device is covered with a capacitive layer with a static charge when we touch a finger on the screen some of the charge shifts from the device to the finger.
This decreased charge is noticed by the system. The system processed the information to the program which tells the exact location of a touch
Capacitive touch screen panel glass types are as follows:
  • • Projected Capacitive Touch (PCT): Uses etched conductive layers with electrode grid patterns. It has robust architecture and is commonly used in point-of-sale transactions.
  • • PCT Mutual Capacitance: A capacitor is at each grid intersection via applied voltage. It facilitates multitouch.
  • • PCT Self Capacitance: Columns and rows operate individually via current meters. It has stronger signal than PCT mutual capacitance and functions optimally with one finger.
  • • Surface Capacitive touchscreen: Coated on one side with small voltage conductive layers. It has limited resolution and is often used in kiosks.
The Capacitive Touchscreens Kit Uses:
  • • Tablets
  • • Smartphones
  • • Android phones
  • • Microsoft Surface
  • • Advertising device
  • • Subway ticketing equipment
  • • Bank automatic withdrawal device
  • • Apple’s iPhone, iPad and iPod Touch
  • • So etc
The article sources url
https://www.vicpas.com/f715679/Top-10-Advantages-and-Disadvantages-of-Capacitive-Touchscreen.htm
VICAPS HMI Parts Center: Touchscreen-Keypad-LCD Displya-Protective Film
Register to Reply 7 comments
crsr1234 (1); cuba_pete (1); Drew K (1); English Rose (1); Shawn33 (1); VICAPS HMI Parts (1); vsar (1)
