Previous in Forum: Where Can I Get RS232 to RS485 Converter in Phnom Penh?   Next in Forum: Capacitive vs Resistive Touch. Why This Difference?
India - Member - New Member
Input Impedance
03/05/2012 11:41 PM
Hi All,
Can any one tell me what is the input impedance of ATmega64A MCU?
Regards,
Rimpul
Re: input impedance
03/05/2012 11:47 PM
What does the data sheet say?
Re: input impedance
03/05/2012 11:51 PM
They have not mentioned in the datasheet.
Re: input impedance
03/06/2012 12:30 AM
Then it must not be a spec of the MCU, but how what your input is in relation to it. How extensive is your electronics background?
Re: input impedance
03/06/2012 12:52 AM
very poor sir, i am just a beginner.
Re: input impedance
03/06/2012 4:29 AM
Have you phoned the manufacturer for advice? If not, why not?
Good moaning!
Good Answers: 82
Re: input impedance
03/06/2012 7:39 AM
The DC input impedance of CMOS logic gates is infinite, so long as the voltage is between the supply rails. They do have a small input capacitance, up to 5pF. But watch out, sometimes devices have internal pullup resistors that can be enabled. Pullup resistors are useful for a variety of purposes, such as detecting closed switches, receiving open-collector opto-isolator signals, or fault outputs from power-driver ICs, for use with wired-OR logic, etc.
The ATmega64A does have internal pullup resistors, although it also has a global pullup disable. The pullup resistor can also be turned on or off individually for each pin. The port-pin schematic above is from page 264 of the datasheet.
Under the topic DC Characteristics, on page 327, the datasheet says the pullup resistor value is from 20 to 50k.
Thanks, Win
Register to Reply 6 comments
Crabtree (1); lyn (1); Mikerho (1); rimpul (2); Winfield Hill (1)
