Previous in Forum: Head Room Clearance Required for Piping   Next in Forum: Friction Inducing Bearing?
Max Working Pressure
03/06/2012 9:08 AM
Hallo to all,
What is the max working pressure in gate valve 800#
Good Answers: 19
Re: Max Working Pressure
03/06/2012 9:27 AM
Maximum working pressure will be dependant on working temperature, and whether you are dealing with a liquid or with steam.
Ask the valve distributer or manufacturer for a pressure/temperature chart to determine to working pressure for your specific situation.
Nominally the 800# valve means 800 PSI rating, but it might vary. Check with the manufacturer, not with some anonomous poster you don't know on the internet!
03/06/2012 10:06 AM
You know, if you had the max working temperature to hand you would have all the information you need to make a phone call to your local friendly valve distributor, and ask.
Good moaning!
Register to Reply 2 comments
