Previous in Forum: Pressure Related Fan Speed Control   Next in Forum: CFBC Boiler
Screw Compressor with Timing Gear
03/11/2012 3:15 AM
Dear All,
What things to be considered during dissasmbe/assemble of screw compressor with timing Gear?
Fahad
Re: Screw Compressor with Timing Gear
03/11/2012 3:22 AM
Please read the service manual for the specific machine. (This is not suitable as a generic question.)
03/11/2012 6:27 AM
Consider everything in the owner's manual having to do with assembly/disassembly, as Tornado suggested.
03/11/2012 6:53 AM
The most critical thing I've always wanted to know before repairing anything is the cost of replacing the whole thing.
03/11/2012 7:09 AM
Thanks to All, I need to hear from Maintenance guy.
04/18/2012 12:24 PM
1-gear backlash -(play) after assembly
2-when disassembly you will find a mark point (The marks are small stamped round indented circles on the outer faces of the gears positioned in line with a gear tooth.)so take care during assembly.
3-Check bearing and bearing pre-load for the right installation
Fahad (1); lyn (1); moamen84 (1); redfred (1); Tornado (1)
