Previous in Forum: Calculation for Load Cell Blank   Next in Forum: Thyristor SCR
Propane Line for Thermocouple RVS
03/11/2012 6:54 AM
i have a 20 year old terry 5th wheel and i need the i/8inch propane line that goes from the furnace regulator valve to the thermocouple for the furnaCE. AANYONE HAVE AN IDEA WHERE I MIGHT OBTAIN THIUS OVER THE INTERNET. THERE MUST BE A SUPPER STORE ONLINE THAT SELLS ABOUT EVEYTHING. THANKS LARRY PLEASE REPLY(JARHEADVET@AOL.COM) furnace is about a 5000 btu small unit
Good Answers: 176
Re: propane line for thermocouple rvs
03/11/2012 9:12 AM
Tough to say without some ID on the heater controls.
The thermocouple bulb, the 1/8" metal line that is a protection sheath for the thermocouple wires and the wire termination are an assembly.
The wire termination end take different forms: wires with spade lugs or a threaded fitting.
The length between the bulb and the fitting varies from one to another.
The diameter and lenght the bulb varies from one to another.
If you can ID the regulator assembly manufacturer, it will narrow your search.
Google furnace thermocouple for thousands of hits
03/11/2012 10:32 AM
http://www.amerhose.com/hose_fittings_valves.php
You don't mention where you are, but if you have a hose shop near you, they can make you one to your exact specifications while you wait. Probably run you less than $10.
03/11/2012 12:05 PM
I'm with Iris on this one. It sounds like a thremocouple and lead.
The propane line would be larger.
Google "thermocoulpes for (insert your model number here)" and see what you get.
I'm supposed to be working this morning and don't have time to look.
03/16/2012 6:02 PM
no its purely a propane line to the flame for thermacouple. 1990 tyerry 5th wheel furnace made byhydroflame corpi think the furnace says 79/80 series. part 2308 robertson grayson main valve
Register to Reply 4 comments
Iris (1); kramarat (1); larry blake (1); lyn (1)
