Previous in Forum: Compressor Oil and Has Separation and Testing of Oil Flash Temperature After Use   Next in Forum: How are Gasket Sheet Made
Heat Soaked Tempered Glass
03/11/2012 11:12 PM
Dear Experts,
Is it possible to differentiate the heat soaked tempered glass and tempered glass? I understand tempered glass has compressive strength of more than 10,000psi. If it is heat soaked after tempered process, will this affect the compressive strength?
thank you
Noel
Wish you luck on your search.
Re: Heat soak tempered Glass
03/11/2012 11:28 PM
Yes, it is possible.
The heat soaked glass will still be in one piece after heat soaking.
03/12/2012 12:08 AM
Hi Lyn,
Excellent and thanks.
Wondering how to identify the value add to the tempered glass on this heat soaked process. ie increase strength? mahy be from 15,000psi to 20,000psi?
Appeciate to hear from you again.
03/12/2012 12:29 AM
Heat soaking does not add strength. It exposes defects that would otherwise cause the glass to fail in service.
This information is easily found by searching.
PRODUCT BULLETIN: HEAT SOAKING
"This causes glass containing nickel sulfide inclusions to break in
the heat soak chamber, thus reducing the risk of potential field
breakage."
Good Answers: 266
03/12/2012 7:50 AM
Will not increase compressive strength it may decrease it though.
As Lyn said it is just a test. It's to find nickel sulfide inclusions that may cause glass to fail in the field.
Added value is to have glass that has less chance of failing in the field. Doesn't eliminate all the defects that may cause tempered glass to fail. Doesn't even completely eliminate failure do to the nickel sulfide inclusions just reduces it. That value is seen where the cost of labor and equipment need is high to do replacements
Re: Heat Soaked Tempered Glass
03/13/2012 9:02 AM
Glass is unstable frozen mass and does not have any crystal structure. Effect of this on
1. Heat soak tempered glass : Based on glass composition some percent of the glass will transformed to crystal structure ( call glass ceramics) and then if we perform tempering then we will have lower compressive strength and will increase young modulus of the glass and will deter glass during failure to small tinny pieces
2. Thermal tempering on the other hand of pure glass will not allow conversion of glass to glass ceramics and will have highest compressive strength. This is good thing if we are laminating the glass it breaks in smaller pieces and stay sticking to lamination material and human injury is not as bad as non tempered glass
Masyood
lyn (2); Masyood (1); noelngke (1); ozzb (1)
