Previous in Forum: Industrial control systems   Next in Forum: protection
How to work out the motor speed of a DC motor?
05/06/2007 2:03 PM
An 8-pole DC motor is supplied at 440 V and carries an armature current of 25A. The armature is wave round with 630 conductors and has an armature resistance of 0.4 ohm. If the flux per pole is 100 mWb, How would you calculate the motor speed? How would you calculate the generated emf? This has had me stuck for days could anyone shed any light on my questions? Regards
Re: How to work out the motor speed of a DC motor?
05/07/2007 12:42 AM
you can calculate it by formula
U-IR=C*(phi)*(omiga)
but the best way is measure with a meter.
to get more precision rotation speed
05/07/2007 12:45 AM
torque equal to
M=C*(phi)*I
c= constant depend on poles etc.
05/07/2007 2:51 AM
The DC motor doesn't have a speed that can be calculated like an AC motor, it's going to be dependant on the inductance/resistance of the coils, the physical loads and the commutation. Imagine a perfect motor, what would stop it spinning faster and faster? You'll need to measure it. Jeff
05/09/2007 1:38 AM
voltage equation for dc motor
E=(fluxperpole*no.of conductor*poles*speed*no.of parallel path)/120
Engineering Fields - Electrical Engineering - Ron Nombri Engineering Fields - Energy Engineering - Ron Nombri Engineering Fields - Power Engineering - Eternal Power Papua New Guinea - Member - Ron Nombri
05/15/2007 4:08 AM
Try calculating using these formulae. Note notations eq.1a...eq.2a are used here to marke equations as stated in numbering order.
1. Torque (T).
Assuming constant flux/pole of weber and an amarture current of divided over a parallel paths, the torque developed is given by
T = (Φ x Z x P x Ia) / 2 x (phi) x a Nm eq.1a
Where: Φ is flux per pole in webers.
Z is number of armature conductors.
P is number of poles.
Ia is armature current.
a is number of parallel paths on the armature.
Practically in dc motors, the Φ and Ia can be varied, hence the torque developed by the motor can be given by
T = k x Φ x Ia Nm eq.1b
Where: k is a constant depending on the physical properties of the motor.
2. Counter emf (Eg).
By generator action of a motor the counter emf is given by
Eg= kΦn eq.2a
Where: n is the speed of the dc motor.
The effective voltage at the armature is the applied voltage (terminal voltage, Vt) minus the counter emf (Eg). Then by Ohm's law the armature current (Ia) is
Ia = (Vt - Eg) / Ra eq.2b
Where: Ra is armature circuit resistance.
Multiplying eq.2b by Ra and making Vt the subject gives
Vt = Eg + Ia Ra is the fundamental dc motor equation. eq.2c
Note that
Vt = Eg + Ia Ra = kΦn + Ia Ra eq.2d
I hope this will help.
Kind regards, Ron
Anonymous Poster (2); cnpower (2); Ron Nombri (1)
You might be interested in: DC Motor Drives, Motor Coils, DC Motors
