Previous in Forum: Design of Rectangular Flange   Next in Forum: Looking for a High Pressure/Low Volume Pump Used in a Harsh Environment
11 comments
Engines
03/16/2012 5:19 AM
What engine shoud i buy? Perkins or Marine Diesel?
Lets say @ 210hp (157kw). Which one is better?
See data below:
Perkins
vs
Marine Diesel
Remarks
1106D-E66TA
MDTD07A
Price
500,000
Price
520,840PERKINS Engines has 6 Cylenders, while Marine Diesel has 8 Cyliners
Power Rating
186 kw (249hp)
Power Rating
157(kw) 210hpremarks
Torque
770 lb-ft320 lb-ftremarks
Reduced Noise
Operates under 88dB(A) at full load.
Reduced Noise
General Data
General Data
remarks
Engine Model1106D-E66TAEngine ModelMDTD07A
No. Of Cylinder6No. Of Cylinder8
Bore(mm)105.5Bore(mm)103
Stroke(mm)127Stroke(mm)97
ConfigurationVertical in lineConfiguration
Displacement(Litres)6.6Displacement(Litres)6.5
AspirationTurbochargedAspirationTurbo
Compression ratio16.2:1Compression ratio21:1
Combustion Bowl125° open bowlCombustion Bowl
Cycle4 strokeCycle
RotationAnti-clockwise viewed on flywheelRotation
Cooling SystemLiquidCooling System
Valves per cycle2
Combustion systemIDI
Engine TypeV8
Engine Crankcase vent systemopen
Max Crankcase press kPa0.5
Physical Data
Physical Data
Length (mm)929Length (mm)812Marine Diesel is handy machine and easy to mobilize and light weight compare to PERKINS
Width (mm)668Width (mm)680
Height (mm)797Height (mm)780
Dry Weight (kg)506Dry Weight (kg)340
Fuel System
Fuel System
Fuel Pump ModelCat HPCR PumpFuel Pump ModelStanadyne (DB)remarks
Injection Timing (°BTDC)-STATICNot ApplicableInjection Timing (°BTDC)-STATIC
Hp rail pressure (MPa)Hp rail pressure (MPa)
Fuel Pump Pressure (In) (Kpa)Fuel Pump Pressure (In) (Kpa)
Fuel Filter Max Particle size (micron)2Fuel Filter Max Particle size (micron)10
Fuel Return System TypeReturn to TankFuel Return System Type
Distance of Fuel (m)1.5
Governor Regulation(5%) 7%
Governor TypeMechanical
Lubrication System
Lubrication System
Lubricating Oil SpecificationSEE MANUALLubricating Oil Specificationremaks
Oil pressure @ 2000rpm-psi30-43
Oil pressure @ low idol-psi6
In pan Oil max temperature(°C)115
Exhaust System
Exhaust System
Exhaust Flow (kg/min)19.45 ( 37.0m³/min)Exhaust Flow (kg/min)( 30m³/min)remarks
Exhaust Temperature (°C)Exhaust Temperature (°C) max600
Max allowable exh backpress kPa7.5
Cold Start Capability
Unaided Start Limit (°C)n/aUnaided Start Limit (°C)remarks
Aided Start Limit (°C)-25Aided Start Limit (°C)
Start Aid ( Optional )Glowplugs fitted as standardStart Aid ( Optional )
Minimum Cranking Speed (rev/min)Minimum Cranking Speed (rev/min)
Unaidedn/aUnaided
AidedAided
Cooling System
Cooling System
Heat Rejected@Rated Speed (kw)105.3Heat Rejected@Rated Speed (kw)91.36remarks
Heat Rejected@Peak Torque (kw)Heat Rejected@Peak Torque (kw)28.1
Coolant Flow (litres/min)263Coolant Flow (litres/min)304
Thermostat-Start To Open (°C)85Thermostat-Start To Open (°C)69
Thermostat- Fully Open (°C)95Thermostat- Fully Open (°C)81
Recommended Cap Pressure (kpa)100Recommended Cap Pressure (kpa)110.32
Max Top Tank Pressure (kpa)100Max Top Tank Pressure (kpa)
Engine Coolant Capacity11
Air System
Air System
Engine Air Flow (kg/min)18.7 ( 16.07m³/min)Engine Air Flow (kg/min)( 15m³/min)remarks
Induction Manifold Pressure (kpa)232.9Induction Manifold Pressure (kpa)
Max intake restriction kPa6
Rec air intake pipe diam mm (min)76
Charge Air Cooler System
Charge Air Cooling SystemAir-to-AirCharge Air Cooling SystemAir-to-Airremarks
Max Total pressure Drop inc Pipes (kpa)10Max Total pressure Drop inc Pipes (kpa)
Charge Air Cooler Heat Rejection (kw)46.6Charge Air Cooler Heat Rejection (kw)
manifold Charge Air Temp. (°C)49manifold Charge Air Temp. (°C)
Turbo Charger
Turbo Charger
Turbo Charger TypeBorg Warner B2 with wastegateTurbo Charger Typeremarks
Max Altitude (m)1500Max Altitude (m)
Performance Data
Performance Data
Friction Power @ Rated Speed (kw)Friction Power @ Rated Speed (kw)remarks
Friction Power @ Peak Torque (kw)Friction Power @ Peak Torque (kw)
Torque @ 800 rev/min (Nm)Torque @ 800 rev/min (Nm)
Electrical System
Electrical System
recommended battery capacity CCAremarks
12 Volt system amp800
24 volt system amp600
max allowable circuit resistance
12 volt system ohm0.001
24 volt system ohm0.002
Re: Engines
03/16/2012 5:45 AM
You haven't mentioned your availability requirements and the ability of the vendors to match it.
You haven't mentioned transhipment costs and capabilities.
There is nothing here about the commissioning time that is needed and the supplier support for it.
You haven't mentioned the warranty considerations, the installation obstacles, any import customs considerations.
Nor have you mentioned any training considerations or standardised spare parts stockholdings, service intervals and downtime considerations.
So how can "better" have any meaning here?
Good moaning!
Re: Engines
03/16/2012 6:04 AM
What's the application? and set up?
Re: Engines
03/16/2012 11:16 AM
Use that one over there. Now pay me my 1% consultancy fee.
Re: Engines
03/16/2012 2:24 PM
What are the available colors?
Pink is contraindicated, but not a deal killer.
Good Answers: 137
Re: Engines
03/16/2012 3:31 PM
What's the currency? If it's $, € or £ I'd expect to get a few of them for 500,000..
Good Answers: 145
Re: Engines
03/16/2012 4:28 PM
Dude,
When its all said and done, it comes down to this. Where and for how much can I get the oil filters for it. in other words what is the maintenance expenditure going to be for the service life of the motor in its application.
Perkins generally has global off the shelf parts availability though if you don't care what it costs you can always fedex what you need when you need it. or be proactive and buy a lifetime suppy of consumables and store it. but then you need to factor in the storage costs to you budget.
We need more information in order to give you more than pressure points for your consideration..
Good Answers: 16
Re: Engines
03/16/2012 6:51 PM
Perkins would be generally the better choice given the two choices, but like the other posters have mentioned there isn't enough information given to make a good assessment.
I would think you should have a T-Bone and Baked Potato tonight as well
Good Answers: 104
Re: Engines
03/16/2012 8:36 PM
Based on the torque ratings, it appears the Perkins is 1800 RPM and the Marine Diesel is 3600 RPM. Your table shows them both to be turbo-charged, but they have about the same displacement, so does the Perkins have a lot more boost? (I suspect the MD is normally aspirated.)
Will either/both of them require gearing for the final drive? That could enter into your final choice.
Re: Engines
03/17/2012 12:29 AM
Well, thank you for all of your comments. I intend to give not complete details because of some reasons. And all of you have a right answer to a wrong question. Thank you very much Guys.
But i will go with the answer of pigg. Thanks Bro.
Good Answers: 213
Re: Engines
03/17/2012 12:39 PM
There are a lot of supporters of Perkins, but I have encountered some issues with non-UK Perkins engines (manufactured in different countries in Latin America). Parts are NOT interchangeable, and the Latin American versions don't seem to live up to my expectations of the Original Perkins line. This experience involves generator sets, not marine engines, but I have the distinct impression that Caterpillar bought Perkins to cover the low end of the market space, and have allowed some corners to be cut...
Re: Engines
03/19/2012 2:34 AM
In the comparison table you should add one more column to show your requirement. Additionally, what is your running requirement and the maintenance expances for the regular running for each engine.
You just see the torque, Marine has just 50% of Perkines, is it suitable to you. Differnce in dry weight, what type of benefit this will give, you have to see.
Register to Reply 11 comments
bigg (1); Codemaster (1); Crabtree (1); cwarner7_11 (1); Doorman (1); Mukesh0861 (1); nexter2012 (1); redfred (1); SolarEagle (1); Tim in Mexico (1); Tobugrynbak (1)
